V&H oval slip-on+pc111 usb need map
Hello,I have a ultra 2007 ,i just buy the V&H oval slip-on and a pc3 usb.I have the map from power commander.Is there somebody who have the map from Jamie at fuelmoto.Just to compare.I look at my sparkplug and the mixture seem to be to rich.
Thank you...
Thank you...
RE: V&H oval slip-on+pc111 usb need map
I have the same setup but with 07 with big sucker, ovals,pc3, the map from fuel moto is totaly different from the pc site. Pcs map runs ok, but fuelmoto is way better. The map will do you no good till you add the air cleaner either a SE from harley or the big sucker cause the air cleaners free flow is what most of the tuning in maps is based on. If you are not going to change to a free flow ac then you need to find a map for your exact setup or have it dyno tuned at a dynojet tuning center.
I do the a/c yesterday and do the remap,then go for a test ride,i like the result ,i look at the plug and they are the rigt color,just the motor seem to run a little bit hotter.Can't run today suppose to have 15cm. of snow.Next week i'm gone try another map just to compare.
Thanks everyone for the help
albngore
01-02-2012 07:44 AM
ironhorseoutlaw3
08-04-2011 02:45 AM
