P1353 code. Suggestions?
Try these posts:
https://www.hdforums.com/forum/touri...stion-efi.html
https://www.hdforums.com/forum/touri...ode-p1353.html
At least gives you a place to start.
If you are using the factory plug wires-not replaced them- the code will pop up with either plugs or plug wires. It is a rather normal code if maintenance has not been done on time. Plugs need to be changed around every 10,000 miles according to the maintenance schedule. I have had it happen more than once.
rherwerth
14
08-28-2008 09:34 AM
