Finally did my breather bypass (pics included)
Old 09-13-2024 | 07:47 AM
ictghost's Avatar
ictghost
Originally Posted by rideonva
Much easier version, no backplate drilling, but not necessarily cheaper, is to replace transmission cover with 2024 model.
The 2024 transmission cover is around $80...I've looked at the Trask cover, which is $375. So the question is, does the 2024 cover have the reed-valve that the Trask version has AND is the fit the same? Any idea?
  #712
Old 09-13-2024 | 07:58 AM
rideonva's Avatar
rideonva
Not sure about the valve, it's slightly taller than older versions of the cover to accommodate oil separator paths, only uses 4 bolts instead of 6. Mine is venting directly to atmosphere, I've routed hose back behind fender fascia.
  #713
Old 09-13-2024 | 09:55 PM
MRFREEZE57's Avatar
MRFREEZE57
Installed the new HD cover on my 114, no reed valve but has oil separator baffle in it. Was easy to install, just screws behind the cylinder are a bear to get out. JMO but I think makes for a cleaner looking job than doing with the air cleaner, I ran a hose up around the ABS module and installed a small filter on the end, can not even notice it unless looking for it.
ictghost (09-13-2024)
  #714
Old 09-14-2024 | 01:05 AM
NorthWestern's Avatar
NorthWestern
Not sure, but quite a few have done it now with success. Man, I have to say, I would have bought it had it been around when I bought my Trask!
My next step is to completely leave out the breathers when I install my new set of heads.
Beartooth Rider (09-14-2024)
hdmatt29
"The Florida Crew"
22
10-18-2012 10:37 PM
bfleischer
07-27-2011 06:45 AM
old skool1983
10-07-2009 10:49 PM
JaronB
06-29-2009 09:48 PM
jskwarek
08-15-2007 10:01 AM
Quick Reply: Finally did my breather bypass (pics included)
