Finally did my breather bypass (pics included)
Old 07-09-2020 | 09:47 PM
kblhd's Avatar
kblhd
Just finished with finial mods by changing down vent from hose to 1/4 SS.
Changed from the photo 3/16 to 1/4 hose. Down hose fitting changed to 1/4 SS tubing
The following 2 users liked this post by kblhd:
MikeTD3 (10-11-2022), tk's sgs (01-04-2022)
  #642
Old 07-09-2020 | 11:08 PM
rcrankin's Avatar
rcrankin
Had to reroute my hoses from up and over, to down and through.
  #643
Old 07-10-2020 | 01:27 AM
Brew61's Avatar
Brew61
Has anyone thought or tried to weld a bung on the lower inside of exhaust pipe and running it into there so anything that comes out just gets burnt off. I know back when we were young in the 70's we would run our PCV valve lines down into a steel line that we had welded onto the collector on our headers on our street rods. That was better then running them into the intake manifolds.
Bruce
  #644
Old 09-07-2020 | 02:57 PM
Johnny4x4's Avatar
Johnny4x4
Stage II
That pill container catch can is cool, I am going to make one.
I was wondering if you get any oily vapor on the engine?
what about collecting rain water?
I am thinking about putting a piece of foam filter in the upper compartment, and the holes drilled on the side.
  #645
Old 09-07-2020 | 04:15 PM
rocket23's Avatar
rocket23
Originally Posted by rocket23
just ordered a tc system from dk customs....better than the homeade hack I did on the sg....
I did a lot of work (exhaust) (removing rattle), last item was th breather bypass....well the oem bolts are brass and did not move when I attempted to remove and replace with the dk set up......well it wasn't going to happen with the tools I have so the project is shelved until I can get me or another better qualified wrench on it...........I'm not ashamed when I know I'm outwitted by a damn bolt.
  #646
Old 09-07-2020 | 04:40 PM
SoCalDyna2015's Avatar
SoCalDyna2015
Did mine. Drilled and tapped the heavy breather. DK customs catch can.
scott_0 (09-07-2020)
  #647
Old 09-07-2020 | 05:17 PM
luckiestiff's Avatar
luckiestiff
Bruce
Exactly what I was wondering
  #648
Old 10-29-2020 | 01:46 PM
bdtaylor1979's Avatar
bdtaylor1979
Finally did mine. Used some rubber hose with a 90 degree bend. Ran down to the small breather filter below. Might put a catch can in place of the filter. It's a screamin eagle backing plate and the breather bolts are 1/2 inch longer bolts made by kuryakyn. Can't really see it behind the stock cover.
Haven't tested it out yet because it's been cold and raining the past 4-5 days here in DFW Texas.
Attached Thumbnails Finally did my breather bypass  (pics included)-photo541.jpg   Finally did my breather bypass  (pics included)-photo932.jpg   Finally did my breather bypass  (pics included)-photo937.jpg   Finally did my breather bypass  (pics included)-photo322.jpg
speedy meadows (08-04-2022)
  #649
Old 10-29-2020 | 03:51 PM
xcbullet's Avatar
xcbullet
You will get drips on your engine, I would think eventually
  #650
Old 10-29-2020 | 04:02 PM
Msquad's Avatar
Msquad
Yeah, best to use catch can or route to ground. I do each way on my 2 bikes. M8 Has catch can that I have to empty. V-rod just routes to ground.
Quick Reply: Finally did my breather bypass (pics included)
