Finally did my breather bypass (pics included)
Old 07-05-2019 | 09:23 AM
skinman13's Avatar
skinman13
$10 off the rack breather from Advance Auto Parts and a brass T fitting. I tried venting down to the road but I found that the oil spray was getting on my brake disk and tire...no bueno!
  #612
Old 07-05-2019 | 04:51 PM
langwilliams's Avatar
langwilliams
I was looking this over an I'm wondering if you could just aim the breather hoses at the outside of the air filter....wouldn't this allow the filter to catch it an keep it out of the engine an off the rear tire. Just clean the filter.
  #613
Old 07-07-2019 | 04:52 AM
rocket23's Avatar
rocket23
Have ya ever seen a ''money shot?!'' but with oil..........thats why it's routed away from everything.
  #614
Old 07-07-2019 | 06:47 PM
Nitro 54's Avatar
Nitro 54
You have a major problem if your getting oil back to the rear tire.
  #615
Old 07-07-2019 | 06:49 PM
rocket23's Avatar
rocket23
agreed thats more than blow by.......last one I did was dumped under the side run along the tranny....I'll do something different with this one.
  #616
Old 07-07-2019 | 11:44 PM
skinman13's Avatar
skinman13
That doesn't make any sense. Oil mixed with air that gets by the breather filters in the heads is designed to exit via the breathers and is vented to the intake to be burned which is not good for your engine, and the purpose of doing a breather bypass is to vent this oil-air mixture either to a collection configuration or an atmosphere dump like I use with the breather filter and other folks do by the tube to the road. After a few thousand miles, especially if you ride hard in hot weather and inadvertently put in a little too much oil, there can easily be a noticeable oil film that spreads rearward around the end of an open bypass vent hose. When my breather filter gets full of oil, I start noticing oil spray on my push rod tubes...now, if that were vented down below the engine without a filter, where do you suppose it goes?
  #617
Old 07-08-2019 | 08:24 AM
blueglide88's Avatar
blueglide88
NO doubt about it, the breather hose dumped under the bike puts a filthy film underside. When I wash my bike I do the underside too once in awhile.
It's not a big problem and not enough to get on the rear tire and make things dangerous. I've dumped it under the bike for 38 yrs with no problems.
Bodacious MC (08-05-2019)
  #618
Old 07-08-2019 | 12:56 PM
GregGillette's Avatar
GregGillette
I too vent to the atmosphere and have a draft tube on the frame. I cut the end at a 45 so points down and not back. No mess on the underside
  #619
Old 07-08-2019 | 02:11 PM
not yours's Avatar
not yours
Default LEDs inside fairing
Originally Posted by Roger That
Thanks Ultra! Did you ever add LED's inside your fairing to illuminate that etching on your windshield?
Wait, wait, wait back up. What is the LED’s inside the fairing thing? I would like to know more
  #620
Old 07-08-2019 | 02:14 PM
not yours's Avatar
not yours
****, I didn’t notice how old that post is. Still what to know.
Quick Reply: Finally did my breather bypass (pics included)
