Finally did my breather bypass (pics included)
Old 10-20-2014 | 08:14 AM
the4thgearkid's Avatar
the4thgearkid
Originally Posted by mike5511
I'm gonna have to agree with you.......and I've done a lot of 300 mile days and several 500+ days.........you can see below what I ride. (Does sound like a good idea though.)
Just curious Mike, are you using syn or dyno oil? I use syn and get a little oil in the air cleaner
  #52
Old 10-20-2014 | 08:46 AM
roadking2014's Avatar
roadking2014
Never a problem here and I'm one of those that keep a "to the full" oil tank and ride pretty hard and engine brake coming down the mountains.
I gotta laugh at my own analogy here but oil blow by is like always shittin in your underwear. you can wear a kotex to hide it but theres a problem inside somewhere that needs attention.
  #53
Old 10-20-2014 | 10:16 AM
GregD's Avatar
GregD
This issue has been on my mind for quite a while.
I just ordered a kit from DK. Going to put that worry to rest.
  #54
Old 10-20-2014 | 10:31 AM
stan60's Avatar
stan60
Originally Posted by DK Custom
Yes, the Discrete Head Breather System will fit the AN BS on a Twin Cam.
DK,,,which one do I need for the 2012 flhtk? I'm tired of cleaning up oil all the time.
  #55
Old 10-20-2014 | 12:40 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
What A/C do you have? From you sig pic it looks like the stock, if that's the case then the Discrete Head Breather System will work.
Just noticed in your sig that it says the Kury Street Sleeper, if that's the case then both the Discrete listed above AND the Premium Discrete, AND the TC Complete Breather System will work.
It's just a matter of what look (or non-look if you want to hide everything behind the football cover) you want.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
  #56
Old 10-20-2014 | 01:05 PM
stan60's Avatar
stan60
Yes, the Street Sleeper with the stock football cover,,,,,
Thank you for the info, I'll be ordering one of those.
  #57
Old 10-20-2014 | 01:29 PM
Nickatnyt's Avatar
Nickatnyt
Originally Posted by UltraNutZ
I was told by a couple of reputable builders to use distilled water in a spray bottle with the bike running.. keep spraying into the TB working the throttle to keep it running. I'll dig up the PMs I got so you have exact/accurate information on how to do it.
I used this method years ago on a Ford V-8. I sold the motor later on and the buyer pulled the heads and later told me that it was the cleanest motor he had seen in a long time.
  #58
Old 10-20-2014 | 01:55 PM
jamess71's Avatar
jamess71
One of these days, todo. Great write up. I'll have to tap the screaming eagle heavy breather too.
  #59
Old 10-20-2014 | 02:18 PM
stan60's Avatar
stan60
Just ordered the Premium Discrete. Ready to be done with wiping oil off of the cam chest cover and pipes.
  #60
Old 10-20-2014 | 02:39 PM
wheel752's Avatar
wheel752
I vented the same way, butt... I tapped for a 10/32 set screw. inside filter housing so no oil can get in.
Quick Reply: Finally did my breather bypass (pics included)
