Finally did my breather bypass (pics included)
Old 08-04-2017 | 07:29 AM
rocket23's Avatar
rocket23
poly treatment might help with heat as well......
  #552
Old 08-04-2017 | 11:01 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by rocket23
first of all ,if everything is working properly, no oil should be spewing out at all......just crank case gases. I think the point we can all agree on no one wants unfiltered crank gases in our motors...how we accomplish it is varied and actually quite interesting, as well as ingenious.
Yes, unfortunately, very rarely is everything working properly...TC's that don't spit Any oil are few and far between.....but like you said, keeping the crankcase gases out of the intake is important.
Here's a NEW External Breather System (EBS) unlike most others.
The Stealth External Breather System, is available in Chrome or Black, & is quite a different look, can blend in, being inconspicuous, and works really well.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
  #553
Old 08-04-2017 | 07:45 PM
Olsen185's Avatar
Olsen185
Originally Posted by golfblues
I hope you drilled a couple holes in the top to vent it. You also need a tube inside it to go to the bottom of the bottle with some sponge filter material around it so it doesn't blow right up the top and out. If you don't have the top vented the system will not work. And if you knew all that, great!
I did not leave enough of a vent. As a result I pressurized the system and oil blew out of the rocker boxes. Spent the last 2 hours putting in new upper and lower rocker box gaskets.
I'm venting to atmosphere again.
Attached Thumbnails Finally did my breather bypass  (pics included)-photo841.jpg
  #554
Old 08-04-2017 | 09:03 PM
golfblues's Avatar
golfblues
Ouch.......good luck
  #555
Old 08-04-2017 | 09:05 PM
rocket23's Avatar
rocket23
was thinking the same thing......
  #556
Old 08-05-2017 | 09:25 AM
bill from tn's Avatar
bill from tn
Ouch Olsen...
I like your hose vent route and will use something similar if my filter creates a mess.
Two questions for others with bypassed vents.
I catch a whif of spent exhaust gas when sitting at a light for a bit. I still have the cats in my pipes so my exhaust doesn't normally put out any exhaust smell.
Am I getting the whif from vented gas pushing thru my filter?
Also, I have slip ons and an open breather, XIED's and a stage one download. Has the bypass vent made enough of a change to affect this. Not really wanting to add a tuner but am considering a change if needed.
  #557
Old 08-05-2017 | 09:44 AM
golfblues's Avatar
golfblues
Originally Posted by bill from tn
Ouch Olsen...
You are smelling the gas coming out of the filter or catch can holes. I just added a little more material in my catch can and do not smell it anymore at all. The filter/can will not affect your tune
  #558
Old 08-05-2017 | 03:31 PM
rocket23's Avatar
rocket23
I get a whiff every now and then....stirs the dna when my ancestors lived in a tree........
  #559
Old 08-05-2017 | 05:44 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Catch-Can with vents.
If you're smelling anything from your catch-can or EBS filter and don't like it, route it toward the back of the bike...doubtful you will smell it anymore.
Photo below-look below the exhaust, near the rear axle, you will see an EBS filter there.
Kevin
  #560
Old 08-05-2017 | 06:18 PM
bill from tn
The smell is not offensive, it reminds me of my old dyna. Just wondered if it was related to the breather bypass.
I only smell it while sitting at a traffic light and only occasionally.
Quick Reply: Finally did my breather bypass (pics included)
