Finally did my breather bypass (pics included)
Old 04-13-2017 | 01:31 AM
NELS's Avatar
NELS
Party hard and ride hard and you'll make it too!
  #492
Old 04-13-2017 | 06:31 AM
Cozz's Avatar
Cozz
Default Take two
Originally Posted by checkers
Cozz, I ran 1/4" 90 degree elbows from both breather bolts behind A/F next to front pushrod tube, venting side by side out of frame tube below oil filter. I cut both lines below frame at an angle to draw crankcase vapor out of tubes at speed. No sludge in lines after a year of riding. Yes two separate 1/4" vent tubes side by side out the bottom, no catch can or filters. I used zip ties at all clean connections. It is subtle.
Pretty much copied Checkers system. Separate vent tube for each head. Will keep an eye on it to see if anything clogs up.
  #493
Old 04-13-2017 | 06:50 AM
rocket23's Avatar
rocket23
"Zackley" same theory, same design. I didn't think anybody on this forum was old enough to know what a draft tube was or a "slobber tube"
diesel motors did up until the mid 2000's....then the epa got to them too.
I had weed whacker fuel line but the neoprene hose the local h/w store offer might be a better fit.......guess I pick up some 3 -4 feet.......1/4 inch the way to go I guess.
  #494
Old 04-13-2017 | 01:34 PM
rocket23's Avatar
rocket23
Originally Posted by rocket23
breather bolts came in I'll post pix in a few days
This cost me a little more than I expected, the k&n a/f I got on flea bay was over sized not allowing me to install the breather bolts, so this one cost me 8 bucks for the hose an clamps, then bust out retail for the right filter! (its an se 1 throttle body).
  #495
Old 04-13-2017 | 06:15 PM
checkers's Avatar
checkers
It won't.
Rockey, what I did is ran a straight 3/4" piece if hose from the breather bolt to a 3/16" plastic 90 degree barbed fitting pointed down. That routed my hoses straight down and close in and away from metal cover. I used the small zip ties at the connections (4) and trimmed off excess. Clean set up. I did this about a year ago, no leaks and don't even notice the rubber lines. I did route mine forward along the pushrod tube down through the frame.
  #496
Old 04-13-2017 | 07:44 PM
rocket23's Avatar
rocket23
yeah, I didn't get a lot of tube, and I stayed away from any fittings....Maybe some nube will be impressed , cuz the words ''fuel injected'' are stenciled on them,lol.
  #497
Old 04-21-2017 | 01:33 PM
blueglide88's Avatar
blueglide88
I am going to do the breather mod this weekend to my Ventilator. I am using brass push-on hose barbed fittings that I ordered from McMaster-Carr part # 91465K11 and push on hose # 5283K31. With this setup you do not need hose clamps. But you have to use that fitting and hose combination. We use these in the plastic injection mold industry all the time on our molds. The hose does NOT come off, in fact you have to cut them off for removal.
  #498
Old 04-22-2017 | 08:28 AM
checkers's Avatar
checkers
I used the plastic barbed connectors and the mini zipties and it's worked for a year with no leaks. This sounds like a good solution also. Would like to see some pics if you are able, thanks.
  #499
Old 05-02-2017 | 08:39 PM
blueglide88
Default push on hose
tucked behind the AC nobody can see the connector
this barb requires no clamp when used with the proper hose, be sure to push it on all the way
FLHTK2015 (05-06-2017)
  #500
Old 05-02-2017 | 08:44 PM
Veekness's Avatar
Veekness
That fitting should be available in the Edelman line at any well equipped mom and pop auto parts store
Quick Reply: Finally did my breather bypass (pics included)
