Finally did my breather bypass (pics included)
Old 02-25-2017 | 05:35 PM
buell95's Avatar
buell95
[QUOTE=pingman68;15970735]Here's what I've done so far. Soon as the gasket comes in I'll get it mounted up.[/QUOTE
How is this suppose to breath?
djhrln (02-25-2017)
  #462
Old 02-25-2017 | 06:53 PM
rocket23's Avatar
rocket23
the filter does what? I'm not critiquing; It looks great, but it isn't a pressurized line , least I don't believe sustained.
  #463
Old 02-25-2017 | 07:00 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
[QUOTE=buell95;15970911]
I was thinking the same thing.
Looks like a fuel filter which are enclosed and directional (I believe)
  #464
Old 02-25-2017 | 07:14 PM
pingman68's Avatar
pingman68
[QUOTE=Uncle Fuzzy;15971217]
Just a collection point for the blow back oil
  #465
rocket23's Avatar
rocket23
anyways, I have all the peticulars/parts and such....I even have a s/s hose I may gut out for the exit too the atmosphere.....but I may not do it at all, once I see whats what after a few months of riding.
  #466
Old 02-25-2017 | 07:37 PM
RG Pilot's Avatar
RG Pilot
You will blow the weakest seal in your motor if you run it with that setup. It needs to vent to the atmosphere or back into your throttle body. What you've done there is "closed" the system and crankcase pressure will build until a seal blows. Then you're screwed. What you need there is a T fitting where you have the two lines going into that filter,, then a line coming off the T fitting going to the filter, then a line coming off the filter and exiting under the bike. You don't need that filter though. All it will do is get clogged with oil and block your system, not as bad as it's plugged by the way you have it now in that pic though! There are a lot of guys putting filters on their breathers but it's pointless unless you clean it very often and the only point of that is to keep the very small amount of oil contained in that filter rather than going out the tube on to the road. Remember, the gasses flow out, not in so you don't need a filter.
  #467
Old 02-26-2017 | 07:50 AM
multihdrdr's Avatar
multihdrdr
As others have mentioned...No Bueno
But the "takeaway" here is that your the backing mods done now
Also for the OCD/**** people, that inconsistent hose clamp positioning would bug me
  #468
Old 02-26-2017 | 08:22 AM
golfblues's Avatar
golfblues
If you drill a few small holes in the top side of the plastic bubble then it will allow it to breathe. Just do it on the top side so it doesn't leak out all over your bike. You can also remove the filter inside the bubble as it will not do a thing but may block one side. Leave a small piece of sponge in there to absorb the oil.
As others have said a tee fitting would be better
  #469
Old 02-26-2017 | 08:34 AM
multihdrdr's Avatar
multihdrdr
That filter looks like an inexpensive one-time use that you don't/can't disassemble
  #470
Old 02-26-2017 | 09:00 AM
golfblues's Avatar
golfblues
You're probably right and actually you need something that comes apart easily to empty. So a T fitting with a catch can with some breather holes in it would be the right way to do it. Make sure a hose goes to the bottom of the catch can with a sponge in it. Or just call DK and order their catch can. I have two and they work great.
Quick Reply: Finally did my breather bypass (pics included)
