Finally did my breather bypass (pics included)
Old 10-03-2016 | 08:14 PM
rocket23's Avatar
rocket23
once ya get past the crankcase pressure as a low number in the first place and probably aided by tb induction.....I kinda think just a vent is needed.
  #392
Old 10-04-2016 | 09:13 AM
RG Pilot's Avatar
RG Pilot
The stock setup will actually have a negative pressure caused by the intake which pulls the crankcase air out as opposed to venting to atmosphere. You'll here about guys saying that when they open the oil cap right after shutdown, they hear air being drawn in. That also means that the umbrella valves are working well too. I had that happen once when it was brand new.
  #393
Old 10-04-2016 | 03:15 PM
wscott's Avatar
wscott
Originally Posted by checkers
A constructive critique: I am not a fan of a "T" between the 2 lines from the breathers. They will compete with each other. I would prefer a "Y" in place of the "T" If you ran the tubes inside out as you did and on the outside of the stand offs, then out the backing plate and both tubes extended to the ground, it would only have 2 tubes through and out, no risk of ingestion. The tube (tubes) extending below the bike should be angled to the rear to create a draft across the end of the tube. My 2 cents.
That advice is right on target.
Scott
  #394
Old 10-04-2016 | 09:07 PM
rocket23's Avatar
rocket23
Well I'm almost ready for the install.....just need shrink tubes and time....total cost 2 dollars.
  #395
Old 10-12-2016 | 04:23 PM
motoman172's Avatar
motoman172
I am sorry gents but I don't understand what to do with the stock breather bolts...
Wont oil still blow through into the airbox even with a bypass?
I have a screaming eagle ventilator style air cleaner and just noticed small oil driping onto my exhaust and on pushrod covers.
Photos would be nice.
  #396
Old 10-12-2016 | 07:34 PM
MikeBel's Avatar
MikeBel
Welcome aboard! Go to the first page of this thread and you'll see a great write-up and pics of the process. Also there are additional tips that others have added. I followed this when I did my bike and it came out great. I did opt to vent below the bike vs. a filter or catch-can. Good luck!
  #397
Old 10-12-2016 | 07:39 PM
Baeseman1's Avatar
Baeseman1
Here's a link to my post where I quoted UltraNutz. He explained his process and has a link to his photos
I copied this almost to a TEE for my ventilator and it's been great since.
https://www.hdforums.com/forum/touri...l#post14985124
  #398
Old 10-13-2016 | 09:19 AM
mgmmgm's Avatar
mgmmgm
Question
Originally Posted by DK Custom
Super Clean set up you built!
Just to clarify, we have air cleaners that have the external breather system built in for as little as $148.95, and we have a variety of external breather systems that work with many other air cleaners besides ours. They range in price from $29.95 to 49.95.
You can see them all HERE
Will the: Premium Catch Can EBS Breather System For Harley Twin Cam, work with the HD ventilator AC set up.
  #399
Old 10-13-2016 | 09:46 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by rocket23
that'll work.....To me it's not a crap ,blow by issue, it's just a pure horsepower mod. crank case air is a higher temperature than outside air, warming the incoming air, cool air adds horsepower even if it's just a minor increment, it's still an increment in the right direction
Equally, if not more important, to adding power via an External Breather System (EBS) is that the crankcase air, besides being warm is oxygen depleted.
It is the oxygen in the air, combined with gasoline that burns, creating power.
With the blow-by air being mostly exhaust gasses that have pushed past the rings, you have air that has little oxygen in it, taking the place of air that could have oxygen in it, thus reducing power.
Another factor is that when the crap builds up on the pistons it changes the compression ratio, meaning that the tune that gave the optimum power prior to the carbon build-up, that tune is no longer optimum for change in compression ratio. This also results in a loss of power.
Below is a chart showing the difference in an engine with/without an EBS.
More charts and info on External Breather Systems can be seen HERE.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
  #400
Old 10-13-2016 | 09:51 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
It will not.
You can use this Catch-Can System with the Ventilator.
You can also use either of the two below with the Ventilator. They come with filters, but you can replace them with a Catch-Can if you like.
Option 1
Option 2
Quick Reply: Finally did my breather bypass (pics included)
