Finally did my breather bypass (pics included)
Old 10-03-2016 | 04:29 PM
RG Pilot's Avatar
RG Pilot
Originally Posted by Just Me
JMO if it wasn't for the fact you can see the T fitting and rubber hose right in plain site it would be a nice setup. The fact that you can I don't like it, looks like a "jerry rig" as they used to call it.
LOL!! Jerry Rig...I remember that. Who the hell is Jerry anyway!?
His air cleaner cover is off in the last pics and it covers that T fitting and a lot of the hose too.
  #382
Old 10-03-2016 | 04:39 PM
RG Pilot's Avatar
RG Pilot
I just did mine last night. I had a SE AC and took it off because it made no difference in performance but it did make a lot of noise. I put the stock air box back on using a K&N element and ran the breather hose inside and then out the bottom with a rubber grommet to protect the hose where it exits the air box. I didn't use a filter at the end but I'm rethinking that; not that it needs a filter because the umbrella valves are one way valves and won't allow air to be drawn in but rather to absorb any oil that comes out of the breather.
  #383
Old 10-03-2016 | 05:20 PM
Just Me's Avatar
Just Me
[QUOTE='14 Limited;15565547]LOL!! Jerry Rig...I remember that. Who the hell is Jerry anyway!?
QUOTE]
LOL! I don't know either.
Don't know what pic your looking at but it is clearly visible with the football on.
  #384
Old 10-03-2016 | 06:02 PM
RG Pilot's Avatar
RG Pilot
[QUOTE=Just Me;15565650]
QUOTE]
True that. I don't know what I was thinking. It is clear on that pic. Heck, I can't even remember who Jerry is though!
  #385
Old 10-03-2016 | 06:50 PM
xcbullet's Avatar
xcbullet
Ya Jerry is the nice way to say it. We actually had a electrician named Jerry in the first shop a worked at, maybe we are the ones that got that started, lol.
  #386
Old 10-03-2016 | 06:57 PM
golfblues's Avatar
golfblues
I believe it was called jury rigged. There was a term called Jerry Built too. Either way both were crappie jobs done with parts on hand
  #387
Old 10-03-2016 | 07:21 PM
rocket23's Avatar
rocket23
all rigs aside, using a adhesive on the joints will not allow anything to be sucked in to the tb eliminating the need for tie downs.
  #388
Old 10-03-2016 | 07:47 PM
Msquad's Avatar
Msquad
Here's my 110 engine reroute. Used 103 parts and drilled hole in backplate to reroute elsewhere.
  #389
Old 10-03-2016 | 07:51 PM
rocket23's Avatar
rocket23
that'll work.....To me it's not a crap ,blow by issue, it's just a pure horsepower mod. crank case air is a higher temperature than outside air, warming the incoming air, cool air adds horsepower even if it's just a minor increment, it's still an increment in the right direction
  #390
Old 10-03-2016 | 08:02 PM
checkers's Avatar
checkers
A constructive critique: I am not a fan of a "T" between the 2 lines from the breathers. They will compete with each other. I would prefer a "Y" in place of the "T" If you ran the tubes inside out as you did and on the outside of the stand offs, then out the backing plate and both tubes extended to the ground, it would only have 2 tubes through and out, no risk of ingestion. The tube (tubes) extending below the bike should be angled to the rear to create a draft across the end of the tube. My 2 cents.
Quick Reply: Finally did my breather bypass (pics included)
