Finally did my breather bypass (pics included)
Old 05-30-2016 | 03:58 PM
bdtaylor1979's Avatar
bdtaylor1979
Originally Posted by Bumpandrun
Another simply no cost hidden way
Is that just venting to the atmosphere or is there a filter back there?
  #312
Old 05-30-2016 | 07:04 PM
Bumpandrun's Avatar
Bumpandrun
Just routed it to backside so it was hidden. From there single hose goes forward than down and under to right side of frame. Pointed away from rear tire. I do run a small gas filter on the end of line. I run on a lot of dirt roads so it just keeps the end of the hose open. Helps to if head breather screws up. But not real important
  #313
Old 05-30-2016 | 08:25 PM
bdtaylor1979
Ok, thanks. I was thinking about doing something similar to what you did.
  #314
Old 07-12-2016 | 06:30 PM
esteboatan's Avatar
esteboatan
Thanks for posting those pics. I will be doing my breather mod in a few days and i think thats the way I will go. Seems simple enough and just hose and connectors will be needed once I put a small hole in the back of the air cleaner.
  #315
Old 07-13-2016 | 12:32 PM
TUCCI's Avatar
TUCCI
Seal the hole or you might get air suctioning around that fitting, you want all air going into the TB to be filtered.
esteboatan (07-13-2016)
  #316
Old 08-12-2016 | 01:30 AM
DK Custom Products's Avatar
DK Custom Products
Sponsor
Here's an example of one of our breather set-ups that is simple to install,looks good, and works very well. If you really want to increase The Look,substituting our braided steel line for the rubber hose will make a noticeable difference. Just to give you some ideas:
Click HERE for more info!
Clint
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
  #317
Old 08-12-2016 | 03:10 PM
Buiceman's Avatar
Buiceman
Thumbs up
Look again at your piston tops in a year or so. You'll be amazed at the difference.
  #318
Old 08-12-2016 | 11:39 PM
bdtaylor1979
Clint
I wonder if you could make that work on a stock intake?
  #319
Old 08-13-2016 | 01:54 PM
DK Custom Products
Sponsor
On a stock air cleaner assembly? Yes,you could. Lots of people have installed an External Breather System, with excellent results. If you haven't already,take a few minutes to look over these various set-ups.
http://www.dkcustomproducts.com/All-...ngines_c76.htm
Clint
  #320
Old 08-13-2016 | 03:57 PM
Makdaddy's Avatar
Makdaddy
Clint
Pay close attention to the last item on that page
Tap and drill set to do your stock instake
Quick Reply: Finally did my breather bypass (pics included)
