Finally did my breather bypass (pics included)
Old 05-12-2016 | 04:45 AM
MikeTD3's Avatar
MikeTD3
Default My Bypass Setup
I've been running this DIY setup for a couple years.
  #272
Old 05-12-2016 | 06:44 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by liquidr1
So let me ask you guys a question. Before I did my cam job and installed the SE billet cam plate and high volume pump, I never got oil puking out my breathers. I also installed the new Woods alpha series lifters. These lifters claim to deliver a lot more oil to the heads than stock. Since I added these mods I get lots of oil puking out the breathers. I even went as far as installing new HD breather assemblies in both heads. Didn't help at all.
longer and higher duration cams will cause this as well. At some point you guys have to realize that getting more oil (or getting more oil faster and under higher pressure) to the top end isn't necessarily an answer to a problem you think you might have.
$280 for lifters? No wonder Bob Wood is so filthy rich!
  #273
Old 05-12-2016 | 07:43 AM
rctreadaway's Avatar
rctreadaway
Originally Posted by Stang951
You got a parts list. Looks nice and clean.
Originally Posted by GriffinDenim13FLHX
Like the look of that setup.
Do you have a filter on the drain line or just a free drip to outside? Thanks for any info.
I actually had seen Smokey Stovers post last week and decided to do my own version of it on mine.
2 - 1/8NPT to -4 AN elbows
5 - -4 AN swivels
1 - -4 AN Tee
3 ft -4 AN Braided Hose
And I also have a catch can I bought just to see what all it's spitting out. The can was $20 and the AN fittings and hose was about $50 all together shopping around on ebay but I really like the look of it.
  #274
Old 05-12-2016 | 09:58 AM
liquidr1's Avatar
liquidr1
Yea, I realize that I probably didn't need to do all that, but I had some extra cash and said what the hell. Im in the cam chest, lets just do it. And now im suffering the oil puking.
Its alright though, I just received my DK Customs breather bypass kit in the mail yesterday.
  #275
Old 05-12-2016 | 06:37 PM
mibeaulieu's Avatar
mibeaulieu
I just ordered the DK Customs Complete HiFlow 606 Air Cleaner Dyna Softail Touring - Rushmore because I like the stock cover. I am going to try the breather bolts - any thoughts on how much oil will weep out of the bolts?
  #276
Old 05-12-2016 | 06:48 PM
Hausguy's Avatar
Hausguy
I had the breather bolts and although they didn't leak anything, they did mist. I got tired of the smell so I ended up routing everything away and behind me.
  #277
Old 05-12-2016 | 07:02 PM
hattitude's Avatar
hattitude
Originally Posted by DK Custom
This is an External Breather System (EBS) that I've been testing out recently.
It is one of our Premium Discrete Systems where I've replaced the filter with a catch can that has a built in filter.
I'm liking it a lot. After testing I was going to go back to the Premium Discrete, but I've decided to leave this on there.
Is that a small catch can? Or is it just a filter with a chrome cover...
  #278
Old 05-13-2016 | 08:23 AM
Makdaddy's Avatar
Makdaddy
I like that catch can Idea, is there a vent I dont see?
Does that Filter breath from the front face as well? Like the new K&N filters
  #279
Old 05-13-2016 | 08:39 AM
Stang951's Avatar
Stang951
When using the AN fittings, does the fitting replace the breather bolt into the head?
  #280
Old 05-13-2016 | 09:10 AM
Makdaddy's Avatar
Makdaddy
No AN Refers to a fitting if you are going to use threaded connections on the hose versus Hose clamps
Hope that helps
DK has some real nice setups
here is a link
I like the drop down filter
http://www.dkcustomproducts.com/All-...ngines_c76.htm
jumpmasterjay (05-15-2016)
Quick Reply: Finally did my breather bypass (pics included)
