Finally did my breather bypass (pics included)
Old 10-29-2015 | 01:03 AM
tundrabuilt's Avatar
tundrabuilt
Originally Posted by bullast
Ive found quite a bit of info with searches throughout the forum.
For that reason, I didn't want to start an entirely new thread.
I figured I could ask here since my questions are in line with this topic.
Ive got the AC pictured below. It has "ears" on it that block the bolts/holes that the vent systems connect to.
I thought it'd be necessary to get the DK until I checked that.
Anybody have any idea how I could vent my TB with this AC?
When I pull the filter off, the throttle body has quite the coating of oil.
Speaking of oil, when I check mine, its at the "Full Hot" line with the engine cold.
Does that mean its overfull, and could be contributing to the oil in the TB?
Im asking because it looks like oil is making its way onto my engine between my push tubes onto the wrinkle black.
How do I clean that off without discoloring or damaging the finish?
Appreciate the help fellas and ladies.
Just did mine the other day...DK needed to make me a custom kit. Hid mine right behind the A/C.
  #222
Old 10-30-2015 | 07:29 PM
BigTwins's Avatar
BigTwins
Not for nuthin', but I don't think anything, no mater how seemingly secure, should be inside the filter.
  #223
Old 10-30-2015 | 08:02 PM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
That's odd, I emailed them a while ago told them I have a Screaming eagle AC. Sent them a picture of the AC, and backing plate. They said they do not make one for that AC. No mention at all about custom, making one...
  #224
Old 11-10-2015 | 07:17 PM
Joe12RK's Avatar
Joe12RK
I did mine a little differently. Drilled and tapped the SE backing plate like everyone, but then tee'd it and ran a hose back between the motor and tranny down to the frame. No need for a filter, it would just collect oil and dirt. There is no back draft to the motor because the breathers have one way valves.
I think it's pretty un-noticable and am looking forward to cleaner combustion air and no oil drip. Just needs to stop raining...
ps while I had it out I polished the backing plate where you can see it.
Attached Thumbnails Finally did my breather bypass  (pics included)-dscf1156.jpg   Finally did my breather bypass  (pics included)-dscf1154.jpg   Finally did my breather bypass  (pics included)-dscf1155.jpg   Finally did my breather bypass  (pics included)-dscf1153.jpg
  #225
Old 11-11-2015 | 01:35 PM
DXHD $100's Avatar
DXHD $100
I did mine the same.
Attached Thumbnails Finally did my breather bypass  (pics included)-breather-1.jpg   Finally did my breather bypass  (pics included)-breather-3.jpg   Finally did my breather bypass  (pics included)-breather-2pg.jpg
  #226
Old 12-18-2015 | 01:36 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I apologize for the miscommunication. We do have a couple of kits that fit your SE A/C. You can see them HERE and HERE
On the AN 10 gauge we do make those one off, this is because we need to modify a part of the AN A/C.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
  #227
Old 12-18-2015 | 03:44 PM
Softy 103's Avatar
Softy 103
Where did you get that braided hose?
  #228
Old 01-01-2016 | 04:26 PM
Baeseman1's Avatar
Baeseman1
Originally Posted by UltraNutZ
here are pics of my ventilator mod. you can see the orange high temp silicone in the holes. Not all breather backplates are the same though.
https://www.dropbox.com/sh/i98t5gg96...TUjvBrG5a?dl=0
here's the rest of the information that goes with the pics above from a previous post of mine for you guys that want to do this. it really is easy to do.
SE Ventilator cause I like the way it looks and I already have it installed. With the K&N filter, flows 287CFM which is fine for the heads I have which flow 252CFM
(2) Dorman 785-410 1/8" MNPT - 1/4" hose fitting (advanced auto)
(10') 1/4" vacuum line (advanced auto) yep plenty left over.
(1) 1/4" vacuum hose "T" (advanced auto)
(1) 1/4" to 3/8" vacuum hose adapter (advanced auto)
(1) Spectre 3991 Breather Filter (advanced auto) http://shop.advanceautoparts.com/p/s...m=spectre+3991
total - $15.49
took the backplate and drilled 25/64" holes in it
Then I used a tap, M10x1.25 to thread the holes
Then I cleaned the breather holes and oil drain holes thoroughly with brake cleaner
Then I siliconed the oil drain holes that go back into air intake (yep that was the only color hi-temp/oil resistant silicone I had on hand.
Then I screwed in the fittings, attached hoses, attached clamps, inserted "T" in proper location, ran the hose inside the front pushrod tubes, and located the filter just behind my oil cooler and fastened in place with a zip tie. The "wetness" you see in that last pic is from my cam change a couple of days prior to this mod.
all said and done, $16 in parts and about 45 minutes of my time that will prolong the life of my motor.
I went this route almost to a T. The dropbox link no longer works, but it did back when I found the thread and gave me the vision to mod my breather.
Thanks NutZ!
  #229
Old 01-02-2016 | 09:53 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Braided Hose LINK
  #230
Old 01-02-2016 | 11:59 PM
jefla's Avatar
jefla
Yeah ...
Quick Reply: Finally did my breather bypass (pics included)
