Finally did my breather bypass (pics included)
#142
Update:
I was not happy with how my breather bypass was fitting together. I went and bought 2 90 AN 6 to 1/8" NPT fittings. My plan was to drill the holes at 90 degrees and use the rest of the set up I posted earlier. 1 of the issues with this is the holes have to be drilled higher up so you have clearance to screw the fittings in. The 2nd issue is the spacing between the 2 fittings was to wide for the rest of my set up. I will plug the holes and go back to my original set up.
What I have learned is 45 degree AN to 1/8" NPT might be the best for the filter and tubing I put together. I may buy a new back plate and 2 of the 45 degree fittings and have a machine shop do the drilling and tapping so that every thing lines up better. This should put the spacing just right for the filter and tubing I used.
#144
Better late than never
Had my indy do mine yesterday. Good thing as it is snowing here in the D FW area right now. Mine was easy to do. I have the S&S teardrop high flow that uses banjo fittings. In the 60 some mile ride back to the house on a combination of both interstate and county back roads my sop feeling is that the engine pulls better not having all that crap going back into the throttle body.
#145
If you run some of chevrons " Techron Fuel injector cleaner (using their concentrated version) in the fuel tank thru the motor 1x or 2x yrly depending on mile ridden it does a good job of not only cleaning fuel injectors or a carb but it also cleans carbon etc from the intake valves , pistons ,and combustion chambers in general too.
Unfortunately doing that wont address the main issue of fouling the air filter ,intake ,or throttle body with oil etc .
I i am seeing the pics correctly its looks as though the original poster of this thread didnt install small cleanable K&N type breather filters which i would do if it was my bike.
Scott
Scott
#146
Installed the breather back on the bike. I am already planning a new revision to this. I finally found a breather with an 1/8" FNPT.
Front View The breather is not centered but I will fix that with the next rev.
Throttle body side:
I think you could easily use AN4 fittings and hose and have less worries about clearance
Throttle body side:
#148
I got mine here
http://www.motosport.com/cruiser/Bik...kcase-Breather
But you can also find them on Amazon and eBay but the prices very from 8.99 to 30+
#149
I got mine here
Did you drill and tap 1/8 npt threads in the opposite end to make the filter duel inlet? All I am finding are threaded on 1 side only & I am questioning if the opposite end is thick enough to tap threads in.
