2011 FLHTK ... slowing down, 30mph in 3rd gear... front end wobble??
anyone else notice this? I first noticed it when I relaxed my hands a bit slowing down one day, I could feel it in the bars, if I release my grip completely, it goes into a severe front end wobble.... just curious because the dealer says it's normal on these bikes.
I took it in for the 10K service and mentioned it to them, this is what the invoice says when I picked it up..
customer states handling concern
DESCRIPTION
"**customer advised the we cannot attempt to duplicate this condition as riding with hands off bars would be unsafe, but that we can check the front end and perform a swing/fallaway check and advise from there."
RESOLUTION
neck bearing adjustment is within spec and no adjustment needed. lubed bearings during 10k service. no abnormal issues during test ride.
Harley does not recommend removing your hands from the handlebars for safety reasons.Harley does design bikes with the rider as an integral part of the chassis and suspension.
couple questions.....
1 is this normal?
also... they were supposed to replace the instrument bulbs not working IF they opened the fairing, when they told me they checked they neck bearing adjustment, I asked if they replaced the instrument bulbs while they had it open... they said they did not have to open/remove the fairing to check the neck bearings and lube ......
2. can they lube the bearings and check the neck bearing adjustment without opening or removing the fairing?
thanks in advance!
Jeri
DESCRIPTION
RESOLUTION
1 is this normal?
thanks in advance!
Jeri
If they checked it with a fall-away check, then they didn't need to remove the fairing for that - or to lubricate it, I don't believe. They would if they had to make any adjustment, though.
*Note: I don't have a fairing on my bike - just flipped through the service manual for that answer.
when you decel- the weight shifts forward onto the front wheel.
if the front wheel wobbles, that motion is transferred to the bike with more effect than if weight is balanced ( cruising) or on the rear ( accel).
long story short- hands on the bars controls your bike better ( and I do ride all of my various bikes with no-hands at times).
note that some riders do/will over correct accidently.
the Guys at the dealer gave you the official story and it's hard to argue with that. the dealer is also responding directly to the problem as described by the owner
first handling checks are always tires, wheels, wheels bearings, neck bearings and suspension.
if braking, then add warped rotors to the list
It seems like they've done that.
if you are not satisfied with your dealer, you could always try another.
i don;t think much of Stubbs ( I live 2 miles from the shop) and have had some warranty work done at arrowhead...26 miles ride for me. ( but they share ownership with Chandler if that's who you doubt).
mike
mike
This is NOT normal, and I don't care what the dealer told you.
