i am sure this isn't the first time this happens. what should i start looking at? or where should i start? does not seem to be associated with bumps on the road seems more random.
Probably a ground issue. There is a ground wire at the upper tree and another couple under the seat, in the well in front of the battery. Loosen then retighten them and see if its better.
