Stuck Breather Gear
Stuck Breather Gear
Hi All, I am new to this forum but have been viewing your posts for years and ran across a problem on my '87 FLH that has me puzzled.
I heard strange noises coming from the cam area so I pulled off the cam cover and removed cam- looks good.
I then went to pull the steel breather and it is stuck in there!
Steel spacer washer cracked in half and scoring on the camcover.
Breather gear turns freely for half a turn then tight for half a turn.
I tried to gently apply pressure with screwdriver to slide it out no luck.
Why is this breather gear stuck in there and how the heck can I pull it out?
Anyone else had this problem?
Plz help.
Thank You
Plz help.
Thank You
