2004 RK Custom FLHRS
Old 01-15-2005 | 01:32 PM
Anton's Avatar
Anton
Stage I
Default 2004 RK Custom FLHRS
Can anybody tell me if a paint set from a 2005 RK Custom FLHRS will fit (with no modification) a 2004 RK Custom FLHRS. The set includes the tank, fenders and side panels. I know the carb vs injected tank is a no go or so I am told. I purchased a 2004 FLHRS that was in a wreck and will have to replace other items also. Too bad there wasn't a way to find which parts are interchangable between Road Kings.
Old 01-15-2005 | 03:49 PM
pococj's Avatar
pococj
Default RE: 2004 RK Custom FLHRS
Part numbers tell at least part of the tale. Buy, borrow, beg, acquire a parts manual, or check with the dealer and see if there are differences in the part numbers. The carb & FI tanks are different and not interchangeable. FI tank has the fuel pump inside, IIRC.
And sometimes even parts with different numbers will interchange. Have fun!
Old 01-15-2005 | 07:30 PM
ApeKing's Avatar
ApeKing
As far as I know no changes were made in the FLHRS between 04 and 05. The only change was the availability of some new colors.
Old 01-15-2005 | 07:35 PM
Sincecrazy's Avatar
Sincecrazy
The body work should interchange no problem, no modification. The difference between fuel injection and carbureted models is that the FI will require both a fuel pump, and a return line on the tank, while the carbureted version will only have the fuel valve.
U-234
03-30-2013 02:07 PM
jim70
Exhaust System Topics
06-28-2011 03:12 AM
AtkRWC
06-04-2009 02:01 AM
jay70546
02-11-2007 10:26 PM
Denbo
06-02-2006 10:55 PM
Quick Reply: 2004 RK Custom FLHRS
