Stange Thing - Engine Light Came On
Hi
Weird thing today. Driving on the way to work, doing about 30 and not shifting, and the bike slowed down, engine light came on and I couldn't accelerate. I could do about 10mph max. I was a few blocks from work so I limped to the parking lot. I could shift but not accelerate. Get to the parking lot and compression is coming out of both pipes. I turn the bike off. I start it up, engine light turns off, and it was running fine. Took it around the block and everything worked fine. Went thru the RPM range up to 4000 no problem. Parked it and turned it off. Started it again and took it around the block again. No problem.
Pull the main fuse and reset everything?
Yep, that's the one. The pins can lose contact and corrode...elec grease gives a more water-tight connection. Also, check your bike to see if it threw a code...
https://www.hdforums.com/forum/ignit...tic-codes.html
