Converting a dual disc wheel to single disc...
Old 09-25-2014, 06:24 PM
StreetGlide23's Avatar
StreetGlide23
StreetGlide23 is offline
Default Converting a dual disc wheel to single disc...
Just curious if you can take a wheel that's set up for dual disc and make it a one disc wheel... by using spacers or anything like that... I know that you can convert the system to one brake by buying a wheel that's already set up for single disc...but I'm wondering if you could convert say a Fat Spoke wheel designed for two rotors to one with a single disc system... this may be a dumb question but I'm just trying to avoid sending the wheel back and waiting another two weeks... Any info would be MUCH appreciated...
Old 09-25-2014, 06:59 PM
ALUCARD19's Avatar
ALUCARD19
ALUCARD19 is offline
Why would you want less stopping power.
Old 09-25-2014, 07:02 PM
StreetGlide23
Question isn't about stopping power... just whether or not it can be done... Thanks...
Old 09-25-2014, 07:14 PM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
That's wtf I'm talking about lol.. I'm sure it can be done if u can find a single in single out junction or puck whatever the **** people call them
Old 09-25-2014, 07:20 PM
KiloGolf4's Avatar
KiloGolf4
KiloGolf4 is offline
I bet you could remove the rotors off of both sides of the wheel and remove the mc off of the handle bar. That way you could show off that sweet wheel.
Brakes are over-rated and completely unnecessary 87% of the time.
eta: this post was pure sarcasm and not meant to be technical advice. You should NEVER reduce the ability of your vehicle to reduce speed. Obviously.
Old 09-25-2014, 07:27 PM
StreetGlide23
It's PRETTY obvious that the stopping power will be reduced slightly... and it's also PRETTY obvious that I'm ok with that or I wouldn't be considering it... now if there is anyone out there who actually has the answer to my question I'd owe ya one... :-)
Old 09-25-2014, 09:08 PM
fj1200's Avatar
fj1200
fj1200 is offline
Is the bike equipped with ABS? If so, I think the answer is no. If no ABS, I would guess using a space the same size as the rotor that is being removed would work. Just thinking out loud and keeping all other comments to myself.
Old 09-25-2014, 09:16 PM
StreetGlide23
Yes it is ABS... I probably should have posted that earlier... It's on a 2014 SGS...
Old 09-25-2014, 09:38 PM
el loco rico's Avatar
el loco rico
el loco rico is offline
I don't think that the rotor on either side is part of the wheel spacer . I think as long as you plug the hose to whatever side you want to remove you should be able to just remove the rotor and caliper and your done . As far as abs I don't know i
f it would work or not.
Old 09-25-2014, 09:42 PM
StreetGlide23
Thanks for all of the replies so far... I appreciate the input... still looking for a definite answer on this before I ship the wheel back tomorrow... Thanks...
Quick Reply: Converting a dual disc wheel to single disc...
