K&N RK-3909 Users-Oil Blowback
Old 04-10-2007 | 07:16 PM
Hinzy's Avatar
Hinzy
Default K&N RK-3909 Users-Oil Blowback
Any of you guys seeing oil blowback in your breathers?
I noticed tonite after a ride oil dripping on timer cover,not a huge amount
just enough to know it was coming from the air cleaner.
Is this a normal occurance or should I be concerned
Thanks Much,
Hinzy
Old 04-10-2007 | 07:37 PM
Bigredone's Avatar
Bigredone
Default RE: K&N RK-3909 Users-Oil Blowback
I get a little on mine. I just wipe it off and wipe the lower inside part of the cover. If you take it back to the dealer, they will tell you to put the stock AC back on to eliminate the problem
Old 04-10-2007 | 07:41 PM
gman's Avatar
gman
search under oil misting, you'll find a lot of discussio on this issue. pretty common, especially on a long, hard ride. Make sure you aren't overfilling the engine oil, i leave mine down about halfway from full.
i have the issue on my WG with a SE AC riding two up on a long distance ride, but thus far have not had that problem on my UC with a AN Big Sucker.
[IMG]local://upfiles/12616/0D4FC00D6C5F40F288B75939BB564495.jpg[/IMG]
Old 04-10-2007 | 07:42 PM
vernh59's Avatar
vernh59
That spray is pretty normal. On the stock breather the oil was piped back into the carb intake. With a hiflow breather there isn't any way to get it into the carb. I installed an HD backplate that has two small pipes from the breather boltd into the carb. Seems to have fixed/ redirected the problem.
OLD SE Stage 1 backplate
[IMG]local://upfiles/5909/3B57D1A041A147D8B6CDB48DFDB96318.jpg[/IMG]
New backplate pn 29510-05
[IMG]local://upfiles/5909/B30F403EC6134F1A826B75B7D1D95503.jpg[/IMG]
Old 04-10-2007 | 07:48 PM
mrsr71's Avatar
mrsr71
Mine does it as well. I just wipe the back (inside) of the cover with an old t-shirt after every ride. No big deal.
Dan
Old 04-10-2007 | 09:06 PM
Hinzy's Avatar
Hinzy
Thanks for the replies,
Hinzy
Old 04-10-2007 | 09:55 PM
iclick's Avatar
iclick
I cut a chunk of black foam rubber about 1x2" and placed it directly under the K&N filter. It soaks up the oil and every few months I'll remove it and wring it out.
Old 04-11-2007 | 07:43 AM
PapaTravis's Avatar
PapaTravis
Hmmm... I have never noticed it. Wonder if something is wrong that I don't have it. I went with a SE, should mine have this issue?
izzyfutch
12-30-2015 09:03 AM
moonsfmc
04-14-2009 12:23 PM
SCHOONER
Oil Archive (no new posts)
12-25-2008 10:54 PM
95hdtlk
EVO
18
06-20-2008 10:59 AM
ManofManyStangs
03-11-2006 11:44 AM
Quick Reply: K&N RK-3909 Users-Oil Blowback
