3Grand 2 spend on hp upgrade
Old 04-10-2007 | 12:29 PM
2d3k2h's Avatar
2d3k2h
Default 3Grand 2 spend on hp upgrade
I'll be sort ..just got tax money back and would like openion on what would be best choices...Have talked to Doug at HQ,Reggie at R&R,Wes at Cyclerama and all say they have the best for that ammount with Cyclerama being slightly higher.I know GMR has a 98 kit,so does HQ and evryone else.Have a 06 street glide stage 1 with Rinehart duals ,SERT,SE AC .Ready to take the next step just lookin for more advice before I spend the money.Would like to keep what I have and add to it to make a reliable,powerful daily ride...what do you all think...Thanks.....I've asked before did'nt get too many resonses..thought I'd try again.
Old 04-10-2007 | 01:07 PM
skyhook's Avatar
skyhook
Default RE: 3Grand 2 spend on hp upgrade
All three of those shops are top notch.The 98" kits are a good product, and they're several hundred dollars more expensive. I'm sure the shops you spoke with are offering a kit that goes something like this:
bore stock cylinders
street port or economy port heads
95" flattop pistons
bolt-in cam like Head-quarters 34, andrews 26, wood 6
Of course you'll need to find a good sert tuner after the build. Some may like higher compression, bigger valves and springs, and bigger cams.These more expensive kits do produce more horsepower at high rpm. But for a bagger like you've got,most riders are happier withthe economy kit with its low and midrange torque.
Old 04-10-2007 | 01:10 PM
gunrunner's Avatar
gunrunner
I guess its up to you, as to reliability, you already have that, bust into the motor and that could go out the window depending on how good the guy is doing the work. If I wanted more kick and garanteed relibility I would take it to the dealer get the SE95" kit and a good set of low to mid range cams, bet it wouldnt cost 3k and be exactly what you are looking for.
Old 04-10-2007 | 01:17 PM
2d3k2h's Avatar
2d3k2h
Thanks guys lookin at the 98"..Phil M loves HQ and Brian loves GMR just looking fof what you guys think before I send the check....
Old 04-10-2007 | 01:21 PM
easyryder01's Avatar
easyryder01
I have to agree with gunrunner Ihave exactly what he described in my bike and I added a few other goodies as you can see and its all there. Unless you wanted to get crazy and just step on up to a 103" well that is another story. Do you still have an extended warranty on your bagger ? This may affect your coverage because it was not done at time of purchase.
Old 04-10-2007 | 01:22 PM
2d3k2h's Avatar
2d3k2h
Oh"and everytime I'm on this forum Brian and Phil have something new that I think I need ....Thanks Phil now I need the DTT and just throw away my SERT I bought for 400 bucks...You guys have any more money tree seeds left///lol[8D]
Old 04-10-2007 | 01:26 PM
2d3k2h's Avatar
2d3k2h
As for my warrenty just got what came with bike so have 8 months left...knew I'd change it up in te future so saved the 1500 they want to extend...
Old 04-10-2007 | 01:58 PM
UltraKla$$ic's Avatar
UltraKla$$ic
ORIGINAL: 2d3k2h
Flip a coin on either.
Old 04-10-2007 | 02:01 PM
gunrunner's Avatar
gunrunner
ORIGINAL: 2d3k2h
Save your 1500. All warranty original or extended will be voided if you do the motor work youre talking about. Only thing is some dealers will cover their work under the factory warranty if done at their harley dealership, another plus for letting dealer do it with harley parts.
Old 04-10-2007 | 02:08 PM
sleepneagle's Avatar
sleepneagle
Trask........Turbo my Bike!
Quick Reply: 3Grand 2 spend on hp upgrade
