Tranny dipstick broke in tranny, removal ideas?
Old 09-18-2014 | 05:41 PM
my74ls4's Avatar
my74ls4
6th Gear
It is a tri-glide, I did not see any reference to tranny pan removal in the service manual. I did see a pic of it in the oil drain procedure. There is a hex nut in the manual that says do not remove. What is that about? If it is only a gasket change it sounds doable. Guess I will crawl under and take a look.
Old 09-18-2014 | 06:12 PM
my74ls4's Avatar
my74ls4
6th Gear
Looked under and all bolts to the cover are accessible. There is only about 3/8" clearance in the front and 1/2" in the back from the skid plate. Is that enough to drop and remove the pan or will the tranny have to be lifted? I can see I will have to remove the crossover pipe.
Old 09-18-2014 | 06:45 PM
my74ls4's Avatar
my74ls4
6th Gear
Fastbagger, Found the oil pan removal procedure in the manual. I was looking for the trans pan not realizing they are one in the same. Looks very doable, even easier since it is a tri-glide. Thanks
Old 09-18-2014 | 06:49 PM
CarrollB's Avatar
CarrollB
I know it won't help the OP but I remember reading about this problem 3-4 years ago. Some thought it was vibration causing the dip stick to break off. In that original thread some cut the dip stick off and just used the cutoff cap to screw back over the hole and bought a spare dip stick that they used just when they needed to check the trans fluid level.
Old 09-18-2014 | 08:22 PM
05UltraBob's Avatar
05UltraBob
^^^^ This sounds like a capital idea. I might just do that, head the problem off at the pass so to speak!
Old 09-18-2014 | 08:54 PM
btsom's Avatar
btsom
When I first read about this about 5 years ago, I made a dip stick out of a small bolt mounted to some radio support stock as a handle. When I got the correct reading on the home made dip stick, I cut off the the one on the fill cap and just use it as a cap. I had assumed that if the stick broke, it would destroy the transmission, never thought it would fall into the pan never to be heard from again. Over the years I began to think I might have been paranoid to worry about this, but here we are again.
Old 09-18-2014 | 08:57 PM
FastBagger07's Avatar
FastBagger07
Whoops sorry guess I didn't read the whole post.I thought you were referring to a bike.I've done those several times but never a trike.Open mouth insert foot.LOL
Ken D
01-11-2018 08:47 PM
jp13
26
10-03-2017 10:41 PM
P51Driver
10-10-2012 05:03 AM
kco
Oil Archive (no new posts)
08-22-2009 11:12 PM
OneBlackFly
04-06-2006 01:48 PM
Quick Reply: Tranny dipstick broke in tranny, removal ideas?
