The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
TOAK-The Thread of All Knowledge-PeckerWoods IMC.
Old 12-23-2014, 11:10 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Nite Larry.
  #35872
Uncle Chester's Avatar
Uncle Chester
Uncle Chester is offline
Took the kiddo around ta look at Christmas lights. Some of them guys go way out for that stuff. Sitting down with some Crown Royal and working on getting chestered.
  #35873
Old 12-23-2014, 11:14 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,986 Likes on 17,897 Posts
Originally Posted by soft 02
Eavnin. Last party done. Base gasket didn't leak! Found another leak. Sux. Nice patches n snakes guys.
Damn dude think you owned a panhead or something Look at the bright side you ever pick up some old iron your already trained .
  #35874
Old 12-23-2014, 11:17 PM
soft 02's Avatar
soft 02
soft 02 is offline
Yup. And I thought my Tramp leaked. Actually it leaked a lot. Never attempted to fix it though. Figured fresh oil every now and then was good plus kept it from rusting.
  #35875
TwiZted Biker
I'd clean the hell out of that with brake clean then acetone , fill the divot with permatex ultra gray , let it dry and forget about it.
  #35876
Old 12-23-2014, 11:18 PM
soft 02's Avatar
soft 02
soft 02 is offline
Im just glad the base gaskets sealed up fine and the breathers are re routed till I can fab up a catch can mount. Till then its a hose on the ground.
  #35877
Old 12-23-2014, 11:20 PM
TwiZted Biker
Don't forget the little dingle berry filter on the end ....
  #35878
Old 12-23-2014, 11:22 PM
soft 02's Avatar
soft 02
soft 02 is offline
Yea right now its a hose to the ground. I have a catch can but I routed the hose between the cyl and down the tank to behind the oil bag. Thats where ill put the can/filter.
  #35879
Old 12-23-2014, 11:23 PM
TwiZted Biker
Anything that will clean the oil residue down in there so the gray can get a grip, torch may work against you in there , how about rubbing alcohol ?
  #35880
Old 12-23-2014, 11:25 PM
soft 02's Avatar
soft 02
soft 02 is offline
Quick Reply: TOAK-The Thread of All Knowledge-PeckerWoods IMC.
