The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
Posers' Coffee House, All Bullshit Accepted, Part IV
Old 03-03-2013, 05:01 PM
gs34doc's Avatar
gs34doc
gs34doc is offline
Big Kahuna HDF Member
Originally Posted by firefighter616
Can't sleep, clowns will eat me
good thing I saved up a couple of .45 n 9mm airsoft thingies
  #12602
Old 03-03-2013, 05:02 PM
rocket23's Avatar
rocket23
rocket23 is offline
Received 3,615 Likes on 2,870 Posts
pft clowns are pussies with face paint, *** 'em......I have some 9 mm rounds somewhere 'eound here.....38 bucks, huh? ***'em
I remember when they were 9.99....and THAT was expensive!
  #12603
Old 03-03-2013, 05:05 PM
krwould's Avatar
krwould
krwould is offline
Received 1,313 Likes on 1,028 Posts
Absolutely....
Originally Posted by gs34doc
Skeery right dere doc... thanks... dunno if I will be able to go out after dark now...
Reeedickuless I tell ya... peeps buyin up reloadin supplies just to resell em and double their money... friggin nutz....
  #12604
Old 03-03-2013, 05:06 PM
rocket23's Avatar
rocket23
rocket23 is offline
ha ha bozo.....what a joke........fukken clowns.........whatever.....
  #12605
Old 03-03-2013, 05:07 PM
krwould's Avatar
krwould
krwould is offline
Sposta get up close to 50* here this week... will see I guess...
Ground is covered again now....
  #12606
Old 03-03-2013, 05:09 PM
hagger's Avatar
hagger
hagger is offline
Old 03-03-2013, 05:10 PM
hagger's Avatar
hagger
hagger is offline
Old 03-03-2013, 05:14 PM
krwould's Avatar
krwould
krwould is offline
Dinner time... laaater...
  #12609
Old 03-03-2013, 05:18 PM
rocket23's Avatar
rocket23
rocket23 is offline
our washin machine is a knockin......***!...cant handle a heavy load........grrrrrrrrrrrrrrrrrrrrrrrrr!
  #12610
Old 03-03-2013, 05:21 PM
Imold's Avatar
Imold
Imold is offline
Received 4,632 Likes on 2,735 Posts
Originally Posted by cjones55555
I'm doing a stage 1 upgrade. I rejetted. I put the washers in. I drilled the plug. Except,,,, there's no screw behind it! Crap. What the hell did I just drill through on my carb?
Google or a thread search should show you a pic that will show where the correct plug is. Now you have to plug that hole so gas stays in and air stays out; I've found that red high temp silicon you can pick up in auto parts stores to be durable, and really adheres; push a little into the hole and you shouldn't have to worry about it coming loose. Just don't get any of whatever you use inside the carb. Some of the expoxies will crack with heat/age/vibration. Even if it seems to run fine after the carb work, check the plugs after putting maybe an hour of highway running, good way to tell if you're still too lean or rich. There's no set rule on those washers under the needle, can be a little trial and error on those; lot of folks have good luck with just going up a low jet size and adjusting the idle mix.
Quick Reply: Posers' Coffee House, All Bullshit Accepted, Part IV
