best glue to attach metal to abs?
Man I don't want to EVER know the answer to that question!!Nobody is going near my nuts with a rivet!
Get a fiberglass repair kit. Use the fiberglass and resin to fasten the nut on and you will never get it back off. Used this stuff to fabricate locking latches to my topper lid on my pickup.
If it looks better should be left to Miz Roo, don't you think? And if the rivet was exposed, it would mess up you underwear, BTW.
Ditto. My dad once glued the bottom tab piece that broke off the inside of a johnny popper cylinder on with jb weld. I know it held for 8 years cuz the guy he did it for drove the tractor till I moved.
what yur doing i don't care,as 4 glue
This glue, there is nothing in this world that works like it. 3M #5200 it's not cheap. U can glue anything on this earth together. u just may not be able to remove it after, with out damage.
