The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
Nitrogen
Old 09-09-2008, 09:43 AM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
I've heard that if you put helium in your tires your bike will sound like a crotch rocket.
  #32
Old 09-09-2008, 10:43 AM
07Fatty's Avatar
07Fatty
07Fatty is offline
Now that was funny
  #33
Old 10-10-2008, 06:33 AM
mopardave's Avatar
mopardave
mopardave is offline
If you fill them with H2O they will hold a much much more consistent temp, pressure and auto balance!
  #34
Old 12-09-2008, 11:38 AM
eazyride's Avatar
eazyride
eazyride is offline
Originally Posted by Dorkman
I will not fly my bike at 40,000 feet, so I'll stick to air...
off course not at 40k feet, nitrogen plays its part when the jet tires land on runways, that is where the tires get massive pressure in regards of all the weight.
  #35
Old 12-09-2008, 11:40 AM
hotrod351's Avatar
hotrod351
hotrod351 is offline
to hell with nitrogen im going with helium. just think of the extra lift.
  #36
Old 12-09-2008, 02:08 PM
J's Avatar
J
J is offline
Originally Posted by RockerMike
I have nitrogen in my car tires. The car runs much smoother and handles turn much better. The tire pressure also stays at the suggested level for a much longer period. When tires are at the appropriate pressure, they wear better and offer greater gas millage. The reason it is better than air is because the molecules are larger. Here is a pdf explaining the weight and size of nitrogen versus air.
www.getnitrogen.org/pdf/graham.pdf
I'm sorry but I find it hard to believe that you can actually FEEL a difference in your ride and handling with nitrogen in your tires.
  #37
Old 12-10-2008, 09:08 AM
mplecha's Avatar
mplecha
mplecha is offline
people will believe anything..
  #38
Old 12-10-2008, 10:24 AM
softail04's Avatar
softail04
softail04 is offline
+ one
  #39
Old 12-10-2008, 11:13 AM
gunner11's Avatar
gunner11
gunner11 is offline
I only notice a change in pressure when I do a bumpy landing.
  #40
Old 12-11-2008, 02:59 AM
mopardave's Avatar
mopardave
Sooooo, you think that normal air is not capable of withstanding the pressures of landing? You are aware that air is almost 80% nitrogen right? LOL
Nitrogen is used in aircraft tires for the pressure stability when going to different elevation and temp extremes.
They (the car tire dealers) are pushing it to make a buck. Nitrogen in your car tires will help keep the pressure stable but you still need to check them every couple weeks, just like air. If you have your own compressor and you install a drier on it, you will have succeeded in getting most of the minor benefits of nitrogen without paying for it.
Quick Reply: Nitrogen
