The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
2003 rd king wont idle
Old 04-29-2024 | 11:32 AM
hdangela's Avatar
hdangela
1st Gear
Red face 2003 rd king wont idle
i have a 2003 road king classic anniversary edition and had it just die on me while riding. I have changed fuse, replaced fuel lines, fuel pump, regulator and housing. It will run now but does not want to idle and back fires and pops?
i am at a loss.
thanks for suggestions!
hdangela
Old 04-29-2024 | 03:38 PM
Hathaway's Avatar
Hathaway
Have you had a diagnostic done on the ECU? Fault codes should reveal something. It might even be the ECU itself. I usually like to do my own work, but when it's this kind of weird stuff, I'd take it in to a shop and see what they say.
Old 04-30-2024 | 06:26 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Fuel injected or carbureted?
You might also want to check the speed sensor. Try cleaning it off or replacing it.
Edit- I see it has a fuel pump so its fuel injected. When does it shut off? While it's rolling down the road, or when you are idling or coasting to a stop?
Old 05-01-2024 | 05:38 AM
hellonewman's Avatar
hellonewman
The idle air stepper motor is probably stuck from varnish or carbon. I had to remove my tank to access the screws to clean mine and it corrected my idle problem.
Old 05-03-2024 | 01:26 AM
Glenn Gorman's Avatar
Glenn Gorman
Check the plug wires.
Pappy J
Engine Mechanical Topics
13
07-04-2023 08:30 PM
Trey W
05-25-2023 08:06 PM
pnh54
02-26-2011 10:38 AM
bb76010
Welcome Area Only
15
10-17-2009 04:44 AM
gunnert
03-08-2008 07:29 PM
Quick Reply: 2003 rd king wont idle
