TOAK, The Thread of All Knowledge part XIV.
Originally Posted by Juan L
Unscheduled at this point and kudos to Mick for going 160 miles without shifting! We think the shaft the actuated the shifter arm is stripped so we are going to shim it and see if we can get that arm tight enough. We will try using strips from a beer can (Mexican of course) to act as a shim.
nevada72 (07-17-2023)
Originally Posted by nevada72
Just came across this pic on the net. It's the Mt Lassen Volcano going off in 1913.
I found it interesting because we all rode through there the other day on the way to Reno. I had never heard of it. I noticed a LOT of very large boulders everywhere in the fields. I guessed that they were volcanic in nature. I'm not sure what the process is, but I would imagine the thing blew it's top sending hot magma into the air, and it cooled into solid form as it returned to the ground. That must have been a hell of a thing to have that raining down.
At least that's what I lied to her.
I’m hoping for the best but I know if it were me doing the repair it would fail miserably
But that’s only because I’m cursed.
dennyo (07-17-2023)
If you have more than one garage door and a belt goes bad for the opener do yourself a favor and replace both. Mine went bad within days of each other from dry rot. Youtube is also your friend because those belts are timed. It isn't like throwing a fan belt on.
In this case, the more malleable the shim, the better, until you get to the point of ridiculous of course.
EDIT: Congrats!!
EDIT: Congrats!!
Juan L (07-17-2023)
Bill, the application of soft metal that conforms to what is left of the splines is exactly what is needed in this case.
