TOAK, The Thread of All Knowledge part XIV.
Re-mornin to all the Woods. Pop is here & we got his truck loaded then get his trailer & put the Gator & tool boxes on there. Planning to take Pop out for Mexican before he heads home
All set up in a campground 2.5 mi from home. LOL
Grandkids want to go camping, so we are camping.
(Don't look at the underside of the canopy as it needs cleaning. I just picked this up cheap late last fall.)
Afternoon Woods! Back from lunch. I wanted a beer with my food but settled for a Coors Light instead
Juan L (06-03-2023)
PapaThiele (06-03-2023)
Afternoon Woodsnitzes. MarkyDos, sounds as if you’ve been busy!
Greg, what model Bitubo shocks did you put on the back?
Russ, I can't find the part# in Bitubo's website, so my guess is this model is no longer available. HD04WV1
The most adjustable High-Performance shocks for your Harley! The WMT-COMPACT Piggyback shocks are designed, tuned and handmade in Italy by world champion race-proven suspension experts. Easily adjustable with a compact hydraulic preload collar allowing up to 20mm of compression adjustment. The exposed remote reservoir featuring a 12 click compression ****, stepless 5 position rebound adjustment lever and fine thread preload nut to help setup the ride for maximum performance. Fully serviceable and rebuildable, including mounting brackets, preload adjustment tool and LONG-LIFE Warranty.
Adjustments:
- Rebound: Stepless 5 position
- Compression: 7 clicks
- Spring preload: Fine Tune Thread
- Compact Hydraulic Preload Adjuster
- 12mm steel rod
- Separated Aluminum compensation Chamber
- Nitrogen charged
- CNC machined billet aluminum heads
Mine don't have the separate reservoir.
More like this
https://www.bitubo.com/Bitubo/cms/EN.../129-wmeo.html
I got from another Forum member.
More like this
Juan L (06-03-2023)
