TOAK, The Thread of All Knowledge Part XIII
In case you guys are too busy planning and missed it ...I HAVE A CONCRETE DRIVEWAY!!!....AND SHOULD BE ABLE TO USE IT SUNDAY EVENING.
No, no, no.......
That's ovulating and if you're able to pull that off you're a better woman than Bruce Jenner.
No plans needed ..you defeat yourself ..just by being you Tinkerbell.. now you get back too spending Mama's money.....same goes to you hose.
You worked the plan! Congratulations.
But you said you were working your plan? Didn't you observe, evaluate and plan? Now you're just going to wing it?
Dammit, I hate when I have loose vowels.
Received 4,632 Likes
Awesome pics Lou.
Yesturday's painting needs sanding now. Haven't painted flakeboard before, smooth turns into take your skin off after painting with latex. Half done with two coats. Other half, just one coat, let dry, sand, and then finish. Maybe it'll work with 2 coats that way, first half will need a 3rd coat after sanding the roughness off. At least it sands quick and easy with a vibrating sander.
soft 02 (06-21-2019)
You may be looking for the San Francisco thread.
