The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
TOAK, The Thread of All Knowledge Part X
Old 10-05-2017 | 05:01 PM
OKMICK's Avatar
OKMICK
Originally Posted by Mark@ Baker Drivetrain
Late shift after lunch check in. Mick step 1 is the water turned on?
Originally Posted by RoadKing 2014
Power on to control/zone box ?
GFI outlet tripped?
Mark, I took a shower this morning and water was flowing.
Chuck, power to controller. Power at leads from box. Problem is somewhere between there and the valves which means about 60 feet of buried cable of which about 15 feet is under my driveway. Good thing it has rained for 4 days, I have to drink beer and consider the solution.
  #7152
Old 10-05-2017 | 05:09 PM
corliss@bakerdrivetrain.com's Avatar
Step 2:
  #7153
Old 10-05-2017 | 05:14 PM
OKMICK's Avatar
OKMICK
Should I use a rubber mallet or steel head hammer, I wanna fix it right the first time, Mark.
  #7154
Old 10-05-2017 | 05:20 PM
Juan L's Avatar
Juan L
Moderator
Originally Posted by PapaThiele
Afternoon Rich, OG and Russ
JuanEl...you back in the US yet?
I am currently somewhere over Canader
zal (10-05-2017)
  #7155
Old 10-05-2017 | 05:22 PM
OKMICK's Avatar
OKMICK
I thought your posts seemed somewhat apologetic.
  #7156
Old 10-05-2017 | 05:25 PM
DanHappy's Avatar
DanHappy
Disconnect both side of the wires going out. Twist one side together. Go to the other side with a continuity meter. If rings wires good.
If it does ring, it's something else. If no ring, run a new pair on the ground ad hook up temporary to see if it fixes it.
  #7157
Old 10-05-2017 | 05:26 PM
PapaThiele's Avatar
PapaThiele
Dude! That is totally brilliant!
  #7158
Old 10-05-2017 | 05:31 PM
OKMICK's Avatar
OKMICK
Never thought of watering my lawn with the doorbell, Dan. I like it.
  #7159
Old 10-05-2017 | 05:32 PM
PapaThiele's Avatar
PapaThiele
A doorbell button that made the sprinklers pop up and spray would be an awesome prank
  #7160
Old 10-05-2017 | 05:40 PM
DanHappy's Avatar
DanHappy
Work enough in steel mills, chemical plants etc... and you learn quickly how to find / fix stuff.
Quick Reply: TOAK, The Thread of All Knowledge Part X
