TOAK, The Thread of All Knowledge Part X
#4881
Hey Al, Yea I think I got it figured out. Gotta run the wiring through the bars TBW and then the left grip wires run along harness under tank and set. Extension harness for ECM that allows you to connect things like grips and heated gear.
The bike comes with an SAE DC Adapter for accessories so she uses that for heated gear. I just didn't want to remove the tank. Last time I removed her tank I scratched it and had to wet sand and get out the DA to buff it out.
They can have a USB port on touring bikes you'd think they would have something inside the headlight for adding on electronics or whatever on a softail.
#4885
#4890
Ever been so far behind at work to the point where ****'s gonna hit the fan and you just closed your eyes hoping it would disappear cause you can't see it?
A project I'm about to start today requires about 2,000 MH to fabricate and the install date is day after tomorrow. I have 18 employees. The math doesn't add up.
