TOAK, The Thread of All Knowledge Part X
Me: Honey, while I was in the garage just now I checked the fluids in your car. I added some brake fluid so your brakes most likely will not feel as soft.
Her: Oh, that's OK, I don't use the brakes much.
Honey-Badger (10-19-2017)
Mornin AlW! Just log into your router and copy all the existing info.....IP, DNS, Gateway...etc. Personally, unless I esperience network issues (constant slow connections, loss of connection...etc) I do not upgrade firmware/software on my network devices.
That might just be the safe way to go, thanks.
Alw
Aerator was removed from one faucet with no change in the issue. Hot water pressure available, no cold water pressure. I think the faucets and toilet valves are plugged on the cold side.
Only on Harley's do you fix it when nothing is wrong...fix it til it's broken!!!
