The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
Poser's Coffee House, All Bullshit Accepted, Part VIII
Old 02-10-2018, 11:46 AM
Imold's Avatar
Imold
Imold is offline
Received 4,632 Likes on 2,735 Posts
My Toro is over 25 years old, first start this winter took 2 pulls. I've had the carb off once and cleaned it out, probably needs a bit more now, surging at idle and needs partial choke while blowing sn*w. Used it twice so far this winter, I can live with the partial choke till it warms up. Maybe even another year or two, I tend to procrastinate. I could say more, but... maybe later.
  #7962
Old 02-10-2018, 01:20 PM
coastie56's Avatar
coastie56
coastie56 is offline
Idle air circuit ia plugged, super easy fix from inside the float bowl there is also a tiny air bleed they don't talk abouton the side of some of the carbs. If it has a pimer bulb a quick and dirty fix is to shoot gummout through the primer tubeso it fills the bowl, then use starting fluid to start it and keep it running for a few until it quits smoking and put fue injector cleaner in the tank. It usualy will smooth out and run with the choke off before you,re done... Check out "Taryl Dactyl" Ha Ha and "Donny Boy " on you tube, great fun on a wintrey day...
  #7963
Old 02-10-2018, 01:29 PM
coastie56's Avatar
coastie56
I also have an OLD 98? 2 stroke Yard Machine blower (MTD), same shape as yours just went through it second time, (Spitting fuel) internal passages fubarred, broke down and ordered NOS Tecumseh carb from EBay. Should be here today. Interesting info on Snowblower Forums .com. Most brands are now made by MTD. Cub, Craftsman, Troy Bilt. Deceptive advertising all use the same couple of Chinese motors but with their brand stickers on them. The average dude with dimples where his knuckles should be doesn't know the difference. You can find all kinds of good blowers on the side of the road in michigan with the same problem, a clogged idle jet because nobody knows where it is, under a plastic plug, ON TOP of the Japanese carb held down by the rubber ring on the idle adjustment screw! Ha Ha. I flip them all the time when I have time...And even funnier, Harbor Freight sells replacement motors for a hundred bucks and folks are just bolting Predator motors in them when they can't fix the Chondas.
  #7964
Old 02-10-2018, 01:56 PM
coastie56's Avatar
coastie56
[QUOTE=Imold;17077924]My Toro is over 25 years old, first start this winter took 2 pulls. I've had the carb off once and cleaned it out, probably needs a bit more now, surging at idle and needs partial choke while blowing sn*w. Used it twice so far this winter, I can live with the partial choke till it warms up. Maybe even another year or two, I tend to procrastinate. I could say more, but... maybe later.[/Q
  #7965
Old 02-10-2018, 07:10 PM
woodtick50's Avatar
woodtick50
woodtick50 is offline
Received 1,198 Likes on 647 Posts
Time for hockey. Blackhawks come north to take their turn at kicking the Wilds azz for them.
  #7966
Old 02-10-2018, 07:12 PM
woodtick50's Avatar
woodtick50
A minute 58 seconds the wild score.
  #7967
Old 02-10-2018, 10:06 PM
rocket23's Avatar
rocket23
rocket23 is offline
Received 3,615 Likes on 2,870 Posts
taxes done.......state got some money....wont be long I'll be out of this place.
  #7968
Old 02-11-2018, 03:48 AM
gs34doc's Avatar
gs34doc
gs34doc is offline
Big Kahuna HDF Member
creeeak.....tiptoe tiptoe tiptoe.......tiptoe tiptoe tiptoe...creeeak, click
  #7969
Old 02-11-2018, 04:10 AM
gs34doc's Avatar
gs34doc
gs34doc is offline
Gotta get my stuff ready and do mine this week.
  #7970
Old 02-11-2018, 05:21 AM
ultracan's Avatar
ultracan
ultracan is offline
Morning Doc. How was Texas?
Quick Reply: Poser's Coffee House, All Bullshit Accepted, Part VIII
