TOAK the Thread Of All Knowledge VIII
#1141
Absolutely spot on, Marcus.
#1142
You have received the Mick stamp of approval.
#1144
#1145
that means YOU, Russ, have received the go ahead to build a server!
See ya, OG
See ya, OG
#1146
Before you go ahead with whatever it was Marcus said be warned I gave the final approval for the Chernobyl reactor.
#1147
MarkyDOS, when you configure it that way, doesn't your GUI have a tendency to slow and get squishy due to the interface with Novotel correction? It would seem to me that you would instead use a Latec M2D4 sensing unit to avoid disruption in the overlink primary signal. Wouldn't you agree?
#1148
MarkyDOS, when you configure it that way, doesn't your GUI have a tendency to slow and squishy due to the interface with Novotel correction? It would seem to me that you would instead use a Latec M2D4 sensing unit to avoid disruption in the overlink primary signal. Wouldn't you agree?
#1149
Stan, I plan to use a Turbo Encabulator to avoid that conflict
A couple of funnies to end the werk day...for those of us that have to
Geez, I mention shufflin and broke the TOAK
#1150
