TOAK the Thread Of All Knowledge VIII
Engineers suck but salespeople who don't tell the engineers the scope of the project suck worse! I find out tonight a 5:30 that the new radio we installed was supposed to have more features enabled than what the engineering staff knew about. So now I have to figure out how to make this thing transmit on two separate frequencies in the 700-800Mhz range poste haste.
Mike I may have time for that Ural ride. Better start now because I heard they aren't too fast.
No, you've been paying for it!
zal (03-06-2017)
Still hoping I might be able to slip out there. Don't give up yet!
When I do my rear wheel, I set the first bearing as the manual says, against the stop. The second bearing is a little trickier since it has the spacer tube in there. I learned through trial and error that you want the tube to be free with as little slop as possible but not touching either bearing. The important thing to remember is what Mike (Imold) said, minimize the side load on the bearing because the rolling elements do not like to ride on the side of the races and will cause premature failure.
Engineers suck but salespeople who don't tell the engineers the scope of the project suck worse! I find out tonight a 5:30 that the new radio we installed was supposed to have more features enable d than what the engineering staff knew about. I have to figure out how to make this thing transmit on two separate frequencies in the 700-800Mhz range.
