TOAK The thread of all knowledge VII
Received 2,087 Likes
Careful! Leonardo Dumbnuts might see that post and blame global warming.
Evening Greg, Tim, Lou, Denny and any others who are lurking
Evenin Woods! Taco Tuesday (the meal, not the gal Jack knows) done. Now to set up the TV and other stuff in the basement. The couch we wanted to put down there won't fit down the stairs or make the turns. Back to that store in a bit for more furniture that will fit.
I haven't seen that style before, mine's a single antenna that plugs directly into a usb port. I recently moved the 'puter to another wall, and it's fine plugged in that way, but on the other wall, the 'puter itself blocked the signal and I had to hang it above with a usb extension cable. This dual antenna on a cord sounds like it would be easier to get the best signal location.
Has mostly decent reviews on Newegg and Amazon. Don't know why Newegg has it listed as low as $25 but only have the option of getting it for 50, makes it much cheaper on Amazon.
How old is your wireless router? I upgraded mine to the newer protocol last year and it made a big difference, streams Netflix 1080 hd and still fast on the puter at the same time.
About a year and a half, should be good.
I might try moving the shops comp around a bit and see if that helps.
Al
What the hell are Minimites??
Ran into that problem ourselves. A chainsaw and an axe works well, Mark.
