TOAK The thread of all knowledge VII
looks to me like every section of the manuals for the older bikes are separate PDF files Mark, but in any one of them you can click on any link and it directs you to the PDF where the required info is. when I try to load the whole file they are located in, it's telling me it's a directory file or something. confusing to me
![Icon Ditto](https://www.hdforums.com/forum/images/smilies/icon_ditto.gif)
It stems from his belief (and I guess pretty well founded) that you can't get the best tune on yer ride without having it actually running in front of you and that the dyno is the only REAL way to achieve optimal results.
Other than that it's pretty much just a "best guess" situation that hopefully will be compensated for if it's within the tuner's tolerance level.
He says he has run into issues many times with pre-mapped tuners
where are my manners, good morning gentlemen.
just heading out to work, thought I'd check in to see if Mike got his files from the dropbox account I made last night
I am following this file issue with some interest! If you guys can get it figgered out maybe I can get the manual for mine too
No argument there Greg. I bought mine when I did the stage 1 upgrade basically trying to save a few bucks.
I will have it for sale when this is all done I reckon..
I think there is a way to create a shortcut with your PDF reader (Usually Adobe Acrobat) to open with the folder containing the manuals as the main page or table of contents. I will look into it as time allows this week
I think there is a way to create a menu page so you can click on the link and go to the section for what you are looking for. Is that how you want it set up? Or do you want one big PDF file?
I'm not sure. My computer skills are so meager that what I'm after is the easiest way to access them. Right now with them on my desk top, I think will work, but if there is a better way to label them and access them, I'm all ears.
I assume I can rename the zip file once I get into them a little to see what's there so I know where to look without having to dig around every time.
I hope this made some sense.
I am a typical end-user with no IT skill, Mark.
