The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
TOAK The thread of all knowledge VII
Old 11-14-2016, 09:08 AM
LiiT's Avatar
LiiT
LiiT is offline
Originally Posted by QC
'03 was the first year for non-forged cranks, so run-out needs to be measured. I think, but Lou may know better, that a Baisley spring and check valve will suffice for oil flow, along with Cyco tensioner shoes. If Mark were putting 15,000/20,000 miles a year on it, I would suggest the total upgrade of the camchest.
I am ready to be shot down in flames over this.
Thanks Greg. I wasn't sure if that was the case on the '03 or not.
I would still inspect those shoes regularly though!
  #12982
Old 11-14-2016, 09:13 AM
LiiT's Avatar
LiiT
LiiT is offline
No flames, but the OE was a **** setup and if I planned to keep my bike for a long time I would probably do it anyway sooner rather than later.
  #12983
Old 11-14-2016, 09:28 AM
AllenW's Avatar
AllenW
AllenW is offline
Originally Posted by LiiT
I got to meet Bert briefly when at OGMark's.
That guy is on a whole other level..
Here's a vid on inspecting cam chain tensioners. Softy, dyna but still applies.
https://www.youtube.com/watch?v=sSPzf1SkeFs
The video gets to the part he removes cam cover and stops, am I missing part of it or is there another video?
Trying to come up with a list of what to look at/replace this winter.
Al
  #12984
Old 11-14-2016, 09:33 AM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Received 20,117 Likes on 10,260 Posts
Morning, morning Woods.
  #12985
Old 11-14-2016, 09:40 AM
LiiT's Avatar
LiiT
LiiT is offline
Morning Russ
Al
This one is better Al.
AllenW (11-14-2016)
  #12986
Old 11-14-2016, 10:04 AM
LiiT's Avatar
LiiT
LiiT is offline
How goes the healing process Russ?
  #12987
PapaThiele's Avatar
PapaThiele
PapaThiele is offline
Received 2,707 Likes on 2,158 Posts
Mornin Russ and Allen!
  #12988
Old 11-14-2016, 10:06 AM
BARACU's Avatar
BARACU
BARACU is offline
Big Kahuna HDF Member
Received 3,567 Likes on 2,621 Posts
Jeez...I leave you guys alone for an hour or so and now you're talking motorcycle stuff...yesterday was cooking! You need to find a motorcycle forum for this kinda stuff.......
  #12989
Old 11-14-2016, 10:11 AM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
I am doing better Tracy when I do what I am supposed to do. Seems that when I am non-compliant and try and do too much stuff is when it hurts the most. I am encouraged that I have broken the code on sleep now which seems to help ALOT! I keep doing my exercises.
  #12990
Old 11-14-2016, 10:26 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,859 Likes on 1,289 Posts
Originally Posted by PapaThiele
The offer stands...maybe I will just let you bring and play your "Now That's What I call Polka"CD's as we work. How's that?
I am super excited...almost to the point of wanting to also do the chain tensioner and compensator while we are in there, but gotta watch the $$$
A new compensating sprocket comes with the DD6. It's a 28 tooth, that's the cool part of the DD6 we don't overdrive the transmission we overdrive the primary. We set all the ratios high so when you install the 28 tooth it brings 1-5 back to near stock and 6th will be the equivalent of a .86:1 overdrive.
It's a more efficient then the standard overdrive.
Standard over drive is 93% efficient
DD6 is 99% efficient
Morning woods.
teeroy_ (11-15-2016)
Quick Reply: TOAK The thread of all knowledge VII
