The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
TOAK The thread of all knowledge VII
Old 11-14-2016, 08:06 AM
zal's Avatar
zal
zal is offline
Received 2,087 Likes on 1,601 Posts
Originally Posted by Northern Glide
Greetings Tim, QC.
MarkII, I had a canooter valve sending unit blow one time. Wasn't pretty.......
Some definitely work better than others. Don't waste your money on the cheap Chinese ones.
  #12972
Old 11-14-2016, 08:23 AM
LiiT's Avatar
LiiT
LiiT is offline
Good morning again fellers.
Originally Posted by PapaThiele
The offer stands...maybe I will just let you bring and play your "Now That's What I call Polka"CD's as we work. How's that?
I am super excited...almost to the point of wanting to also do the chain tensioner and compensator while we are in there, but gotta watch the $$$
Don't know about the '03s but mine had the evo style primary chain tensioner. We (OGMark) swapped it out too while we were at it.
Have you done yer cam plate upgrade yet?
I'd get the Canadian canooter valve. Nobody builds canooters like a Canadian!
  #12973
Old 11-14-2016, 08:25 AM
PapaThiele's Avatar
PapaThiele
PapaThiele is offline
Received 2,707 Likes on 2,158 Posts
I am unsure what has been done to the cam late, Tracy. I think the previous owner did something but haven't made the effort to pull it apart just to look.
  #12974
Old 11-14-2016, 08:33 AM
LiiT's Avatar
LiiT
LiiT is offline
That was the real Achilles heel of our early TCs. Definitely check your tensioner shoes for wear. Would be really bad if one gives out.
I did the SE cam plate upgrade at 42K on mine and they still looked pretty good, but that's something you definitely don't want to take chances with. The upgrade also gets you a bigger oil pump.
One more bit of advice on them. If you do the upgrade, go to the gear drive instead of chain. Gear drive gives you the option of using a lot of the newer cam setups.
You are gonna love that DD6!
  #12975
Old 11-14-2016, 08:38 AM
Freak Show's Avatar
Freak Show
Freak Show is offline
Morning Tim, Stan, Tracy
  #12976
Old 11-14-2016, 08:41 AM
PapaThiele's Avatar
PapaThiele
Do our generation of TC88's have to be measured for crank run out before I go with the ear drive cam plate?
There has t be a joke about wives and "crank run out", right? Something like they never run out of crankiness in the mornings?
  #12977
Old 11-14-2016, 08:49 AM
LiiT's Avatar
LiiT
LiiT is offline
I'm not sure but I think they still had the forged crank and Timken bearings, so no. They are (IMHO) actually the best TCs to build on because you have a good solid base to work from.
Later models are where that becomes an issue. Not an expert on this, just going with what I know on my bike.
  #12978
Old 11-14-2016, 08:56 AM
AllenW's Avatar
AllenW
AllenW is offline
Originally Posted by QC
Gonna need all the seals for the inner primary. Probably an inner primary bearing. I'll need to see the instructions so I can study up on it.
This might help.
al
  #12979
Old 11-14-2016, 08:59 AM
LiiT's Avatar
LiiT
LiiT is offline
I got to meet Bert briefly when at OGMark's.
That guy is on a whole other level..
Here's a vid on inspecting cam chain tensioners. Softy, dyna but still applies.
  #12980
QC's Avatar
QC
QC is offline
Received 19,803 Likes on 9,866 Posts
'03 was the first year for non-forged cranks, so run-out needs to be measured. I think, but Lou may know better, that a Baisley spring and check valve will suffice for oil flow, along with Cyco tensioner shoes. If Mark were putting 15,000/20,000 miles a year on it, I would suggest the total upgrade of the camchest.
I am ready to be shot down in flames over this.
Quick Reply: TOAK The thread of all knowledge VII
