The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
TOAK- Thread Of All Knowledge- Part VI
Old 07-11-2016 | 08:19 PM
dennyo's Avatar
dennyo
Good Luck Lou ,
  #13612
QC's Avatar
QC
Lou, can you tap it out to 1/4-18 or 3/8-18 NPT so you can fit a more flush fitting plug?
  #13613
Old 07-11-2016 | 08:21 PM
QC's Avatar
QC
Originally Posted by BARACU
Tracy....did you notice it's a SMOKE FREE property???
I smoke too. I've traveled enough so it's not that big a deal.
  #13614
Old 07-11-2016 | 08:25 PM
soft 02's Avatar
soft 02
Not on an 07. Plug is 1/2-20 o-ring thread plus tapping it out for the Heli coil last time made the hole quiet large. When I get back ill order a Big-Sert and be done with it.
  #13615
Old 07-11-2016 | 08:39 PM
zal's Avatar
zal
Evening Woods!
Thanks Greg and Gloria for bringing the treats. And can't wait to have Cindy Lou Spaghetti!
I'll probably eat a bit out and also cook in the room, depending on whats there to use. Also a good time to unwind with a beverage.
Shitty deal Lou, can you get a time set in before you leave? I have only used a time set once, expensive set to buy. It was a 7/8" NC for a chipper blade holder on a wood chipper.
  #13616
Old 07-11-2016 | 08:47 PM
QC's Avatar
QC
Evening, Tim. Time-serts are a bit more expensive. When you start talking that size, they can get REAL expensive.
P.S. Got any bodies that need disposing of? That chipper will take of anything!
  #13617
Old 07-11-2016 | 08:52 PM
soft 02's Avatar
soft 02
$122 for the Big-Sert set and no. Even expedited it will only get here on the 15th.
  #13618
Old 07-11-2016 | 08:53 PM
soft 02's Avatar
soft 02
Got my loose tail light fixed. Now im gunna detail her a bit.
  #13619
Old 07-11-2016 | 09:09 PM
AllenW's Avatar
AllenW
Didn't it say designated smoking area's?
Lou, did the helicoil just come out?
If so, what are your steps to install the coil?
I've had good luck first cleaning the threaded hole with brake cleaner or carb cleaner which is usually a bit more aggressive imho, then inserting the coil with red lock tight and screwing plug in finger tight and a bit more.
Let sit over night then remove plug and coat with antiseize and re insert, a hair less snug than you usually do.
I drill out the plug and run a wire keeper also as I'm not over tightening the plug.
Seems to work for me anyway.
Al
  #13620
Old 07-11-2016 | 09:11 PM
PapaThiele's Avatar
PapaThiele
Smoke free?! Ahhhh!
