The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
TOAK- Thread Of All Knowledge- Part V
Old 05-03-2016, 01:13 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Originally Posted by Northern Glide
OK - In need of a refresher edumacation........
Is run-out defined as horizontal movement of a shaft, or an out-of-round condition of the shaft itself ? I assume in each case we're not talking about bearing problems.
Or is it something different?
Thx in advance.
Out of round condition or following a non circular path but more of an elliptical one. 03-16 bikes the crank just floats in the bearing per say and is held horizontally by the comp and the crank/cam sprocket.
  #30212
Old 05-03-2016, 01:17 PM
soft 02's Avatar
soft 02
soft 02 is offline
Originally Posted by LiiT
Put my little dozer on Craigslist. Hoping for a bite soon!
http://lexington.craigslist.org/hvo/5568579080.html
What % worn is the undercarriage? One of the things I look for when buying a dozer. FWIW a complete under carriage is about $4500 from JD. Do you know how to adjust the brakes? its super simple.
  #30213
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,859 Likes on 1,289 Posts
Don't worry Stan we have seen some new ones like yours that were only .007-.008 out.
  #30214
Old 05-03-2016, 01:26 PM
LiiT's Avatar
LiiT
LiiT is offline
Percentage wise, I couldn't tell you. All sprockets look good and have plenty of wear left on them. A few years back I took it to a place in Richmond for some work and all they said was that it looked pretty good at the time. I may have put a little over 150 hours on it after that.
Yeah I know how to adjust them and yes it's pretty simply done. I'm pretty sure it needs new pads. The 450B is a dry brake system and they can wear pretty quick if you have to do a lot of turning.
  #30215
Old 05-03-2016, 01:39 PM
soft 02's Avatar
soft 02
soft 02 is offline
Maybe add "85% on undercarrige". That wood peak my interest. I figure market value for that dozer is 10-12k but the winch adds more value. That winch is a beast! Pretty simple too. Wish i was in the area.
  #30216
Old 05-03-2016, 01:41 PM
Northern Glide's Avatar
Northern Glide
Northern Glide is offline
Received 3,917 Likes on 2,815 Posts
HaHaHa.....I assume it should be more like .0015.......
Does that suggest the crank in not true round passing through the bearing.......or that the crank has a slight "bend" to it?
Not sure how the bearing "floats" unless the bearing interface has extra tolerance built into it.
Thx
  #30217
Old 05-03-2016, 01:52 PM
PapaThiele's Avatar
PapaThiele
PapaThiele is offline
Received 2,707 Likes on 2,158 Posts
Let's not get into who has a bend in their crank shaft, k?
  #30218
Old 05-03-2016, 02:01 PM
Northern Glide
HaHaHa.....Maximus , we're all family.....right?
BTW, my run-out has gotten pretty bad with aging. It's now run-in.
  #30219
Old 05-03-2016, 02:05 PM
Northern Glide
Hope for all of us I guess. Long as you have an el-largo bank account.
http://www.people.com/article/david-...hayley-roberts
  #30220
Old 05-03-2016, 02:09 PM
PapaThiele's Avatar
PapaThiele
Went from an outtie to an innie?
Quick Reply: TOAK- Thread Of All Knowledge- Part V
