The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
TOAK- Thread Of All Knowledge- Part V
Old 03-30-2016, 07:49 AM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Received 20,117 Likes on 10,260 Posts
Old 03-30-2016, 07:51 AM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 49,835 Likes on 19,328 Posts
Nope ... Never had one ( primarily ) because of all the problems ( I have a buddy who has one ) with keeping them stuck where they belonged. I have read about using the Tour Pack bolts to keep it in place. Might work.
  #20393
Old 03-30-2016, 07:52 AM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Originally Posted by PapaThiele
Anyone else have a tour pack lid organizer that has curled due to heat over time? I saw a thread about installing a new one but figured this being the TOAK, y'all could tell me if the VHB (Very High Bond) velcro would be enough to hold it flat against the lid once again.
My other idea was to glue it to a piece of masonite and bolt it with the luggage rack bolts but that a little more work and not sure what glue/caulk to use.
The problem with the VHB velcro is the tensile strength of the hook and loop system will be overcome by the curling effect of the warped organizer. The only thing you will accomplish is having the velcro stuck really good to your lid. Try taking the organizer out and gently heating it with a heat gun while laying it on your garage floor to try and straighten it. Don't overheat it or you may find out if it melts.
  #20394
Old 03-30-2016, 07:55 AM
PapaThiele's Avatar
PapaThiele
PapaThiele is offline
Received 2,707 Likes on 2,158 Posts
Thanks Larry. I mostly use it to hold bandannas and clear lenses. Nothing terribly heavy. It was already curled wen I bought the bike. Last year I heated it in the sun then weighed it down to flatten it, then used Gorilla Glue Tape but that didn't even last 6 months. Maybe I will see if I can live without it.
  #20395
Old 03-30-2016, 07:56 AM
zal's Avatar
zal
zal is offline
Received 2,087 Likes on 1,601 Posts
Morning Woods.
Happy Birthday Cindy.
No tour pack, so I can't help you Markus.
  #20396
Old 03-30-2016, 07:57 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,859 Likes on 1,289 Posts
What's a tour pack?
  #20397
Old 03-30-2016, 07:58 AM
PapaThiele's Avatar
PapaThiele
Russ...I had thought the same thing, the velcro would be the weak link. Is a hair dryer comparable to a heat gun or do I need to make a run to Harbor Freight? My wife failed to clean the lint screen from her last hair dryer and just replaced it without asking me if there was anything to be done to salvage it. I inherited it rather than trashing it, cleaned the screen and it heats up just dandy
  #20398
Uncle Larry
Markwood, It's almost like a twelve pack except without the twelve
  #20399
Old 03-30-2016, 08:01 AM
I'm not fixing an empty twelve pack.
  #20400
Old 03-30-2016, 08:02 AM
Uncle Larry
You shouldn't have to, you already did ( burp )
Quick Reply: TOAK- Thread Of All Knowledge- Part V
