Poser's Coffee House, All Bullshit Accepted, Part VII
Received 1,313 Likes
OK...back from the dayz wurk......Rode down an put the fuglybike onna dyno. Installed the TTS Mastertune and made the necessary adjustments to get everything to an acceptable level.
I had previously installed a high-flow air intake and a 2 into 1 exhaust system, so I don't have any idea about the stock configuration HP or Torque.
This shows the initial run without the tuner and the final run with everything adjusted.
Take it for what it's worth...
That big hump in the AFR wuz what we were out to get rid of, and you can see the final run the line is flat.
I might havta take a trip down there myself.... still poppin but not as bad... pissin me off though!
Yep, looks good on paper.....seems stronger.
When I wake up. Everybody else should too.
I been up since 5:15.. the dawg finally got up....
Don't know what you'd have to do to get rid of that completely. There's a lot that TTS can do but you've almost got to take the screenshots and go back into the tables line by line. ..Might take ya days ta do sumthin like that!!!
