Hey cHarley... How do you think that got busted? Did it crack? Got pics?
Glad to hear the replacement is on its way. See ya soon.
I had my fork tubes off rebuilding them yesterday. I got everything back together and snugged in place then got out the torque wrench, set it to 34#'s ( specs are 30 - 35 ft #), tightened the first 2 pinch bolts fine but when I got to the third, the tree cracked where it wraps around the tube next to the pinch bolt.
When you do it the right way, using a torque wrench, this chit leaves you scratching your a$$.
I am glad that it happened up on the jack instead of while you were barreling down the road.... Glad you found a new one so fast as well. See you soon.
