"The Florida Crew" Rides and Information From The Florida Crew.
Must Have tools in the shop!!!!!
Old 09-02-2010 | 02:51 PM
big_al's Avatar
big_al
Default Must Have tools in the shop!!!!!
I copied and pasted this from one of the other boards....truly classic stuff...:
I'm sure none of us have EVER used the last one .....
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your soda across the room, splattering it against that freshly-stained
heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprints and
hard-earned guitar callouses from fingers in about the time it takes you to say,
'Yeouw....'
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age, or for perforating something behind and beyond
the original intended target object.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs. Caution: Avoid using for manicures.
HACKSAW: One of a family of cutting tools built for frustration enhancement.
It transforms human energy into a crooked, unpredictable motion, and the
more you attempt to influence its course, the more dismal your
future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the
conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2 socket you've been searching for the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack handle
firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile upward
off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most
shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength
of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end opposite the
handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called
a drop light, it is a good source of vitamin D, 'the sunshine vitamin,'
which is not otherwise found under cars at night. Health benefits aside, its
main purpose is to consume 40- watt light bulbs at about the same rate that
105mm howitzer shells might be used during, say, the first few hours of the
Battle of the Bulge. More often dark than light, its name is somewhat
misleading. The accessory socket within the base, has been permanently rendered
useless, unless requiring a source of 117vac power to shock the mechanic
senseless.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under
lids, opening old-style paper-and-tin oil cans and splashing oil on your
shirt; but can also be used, as the name implies, to strip out Phillips screw
heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that travels
by hose to a Chicago Pneumatic impact gun that grips rusty bolts which
were last over tightened 40 years ago by someone at VW, and instantly rounds
off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts adjacent to
the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well on
contents such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially
useful for slicing work clothes, but only while in use. It is also useful for
removing large chunks of human flesh from the user's hands.
DAMMIT TOOL: (I have lot's of these) Any handy tool that you grab and
throw across the garage while yelling 'DAMMIT' at the top of your lungs. It
is also, most often, the next tool that you will need after a really big
hammer
Old 09-02-2010 | 03:40 PM
Big Vic's Avatar
Big Vic
hehehe
Old 09-02-2010 | 03:47 PM
Fatboy Brian's Avatar
Fatboy Brian
Been there done almost all that.
Old 09-02-2010 | 07:34 PM
themensh's Avatar
themensh
part number for the dammit tool please.
(Lost the last one I had)
chuck
Old 09-02-2010 | 08:03 PM
redman53's Avatar
redman53
Think I've done it all...several times...especially the damnit tool...sometimes in extreme cases it becomes the f **kit tool also
Old 09-02-2010 | 08:14 PM
SoFla's Avatar
SoFla
Have used the dammit tool before. My version also looked like an awl. Slipped, stabbed myself with it and threw it across the kitchen yelling dammit. Then the big dammit happened as I watched the awl (in slow motion turning over and over again) sail across the room. Only to embed itself in the pipe of the radiator heating. Water starts shooting across the kitchen as I tell my wife she had to call her father and get him there to fix it. It was our first home, and he was the landlord. Try explaining to your father-in-law how that happend with his daughter in the room.
Old 09-02-2010 | 09:41 PM
CapeSalyers's Avatar
CapeSalyers
THANK YOU! I needed that! After a bad day at work a good laugh helps!
Old 09-02-2010 | 10:14 PM
murph's Avatar
murph
Been there and bought the t-shirt.
Old 09-03-2010 | 06:47 AM
redman53's Avatar
redman53
Old 09-03-2010 | 04:35 PM
big_al's Avatar
big_al
Glad you enjoyed it!!!!
Quick Reply: Must Have tools in the shop!!!!!
