DYNOJET: Dyno tune and pv questions.
Sorry everyone but I am an idiot when it comes to tuning and I can’t find what I’m looking for when searching the threads.
Ive had heat issues with my 17 fxdls since I installed my se 117 kit. On a 80 degree day my pv reads engine temp around 280. It doesn’t take much to hit 300 either. Originally I ran a pv auto tune and every month or two the exhaust studs (front cylinder) would break. After break in I had my dealer dyno tune it. I still had heat issues and even cracked the head pipe on my fat cat twice. I shut It down if it hits 300. The bike has been down for a while but I believe it’s running lean. Hoping to confirm this when the weather breaks. Sorry for the long winded background but that’s all the relevant info I can think of.
Assuming it is running lean, do you suggest I adjust global fuel in quick tune, or by rpm range? Or something else all together? I’m happy with the power and torque curve so I don’t want to lose power if I don’t have to. It puts out about 122 ft lbs which is good enough for me for now.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Have your tuning shop check the tune. 300 degrees will not crack studs or the exhaust system, something else is going on there, a stock Twin Cam 103 will surpass that temperature in warmer weather. A running temp of 280 is completely normal.
thank you. Any ideas specifically? Only thing I can really think of is just removing it, installing the headers and torquing them down, then installing the pipe and torquing it last. It’s a d&d fat cat so there isn’t much in terms of adjustments. Thanks again.
Mchad
07-10-2016 12:54 PM
ryan9977
06-17-2015 09:16 AM
2mOOn
09-08-2014 07:25 PM
