DYNOJET: Power Vison easy way to see Calibration loaded in ECU
I’m having a senior moment and can’t remember if I loaded a map other than factory, I know I married the PV and saved the factory calibration but don’t remember if I loaded a Fuel Moto map.
Any way to tell without re-flashing?
(I’m not near the bike at the moment... so I can’t just poke around and see ... )
Yes, you can get the current tune from the ECM and save it to the power Vision. Then you can get the tune from the PV with WinPV and check it or compare it to the stock tune.
From Chapter 4 of the WinPV user manual-
To Load a Copy of Current Tune File
Use the following steps to load a copy of the current tune file to the Power Vision.
The current tune file is the tune that is currently in the ECM.
1 Turn the ignition key to the On position.
2 Verify the Run/Off switch is in the Run position.
3 Touch Program Vehicle >Load Tune >Load Copy.
4 Touch Load Copy of Current.
This will load a copy of the current tune into the Tune Manager. Once loaded into a slot, it will be converted into a custom tune which can be edited and/or flashed to the ECM.
